radiator with holes
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, radiator with holes in Cadillac Engine Discussion; Hey all recently i have found out that my radiator has an internal leak and i need to buy a ...
    capn's Avatar
    capn is offline Cadillac Owners Fanatic
    Automobile(s): 94 Eldorado ETC
    Feb 2004
    NC PM me if your around here
    216
    Angryradiator with holes
    Hey all
    recently i have found out that my radiator has an internal leak and i need to buy a new radiator, where is a good and reputable place to buy from?
    capn
    Aurora By Olds is offline Cadillac Owners Fanatic
    Automobile(s): 2000 DTS
    Oct 2003
    Fort Myers, FL
    33
    197
    Re: radiator with holes
    My '95 service manual shows the radiator as fully servicable. You may want to find a shop that "rebuilds" them. I know there are a few around here who can do it for much less than new.
    capn's Avatar
    Feb 2004
    216
    Quote Originally Posted by Aurora By Olds
    well i would rather buy a new one b/c this has like an internal leak, and more like piece of mind ya know
    Lawrence's Avatar
    Lawrence is offline Cadillac Owners Fanatic
    Oct 2003
    Ohio
    334
    Personally I would use the GM PN. $294.82 at www.partszoneonline.com You should never have to replace it again. If you do go aftermarket go with the Modine. I have had bad luck with all the others.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    I don't have a problem going aftermarket but if it's aluminum only replace with aluminum.
    I got my last one from Radiator barn. Cheaper, name brand, fast delivery. I looked at 95 STS's on several sites. From $178 to 205. Your choice.
    http://dev.autocoolradiators.com/
    http://www.radiatorbarn.com/main.asp
    http://www.discountradiators.com/
    Or do a search on yahoo. These all show the same pn.
    BeelzeBob's Avatar
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Quote Originally Posted by capn
    Hey all
    capn
    An "internal leak" implies that one of the oil coolers is leaking internally..???
    If so, the end tank and the cooler is readily replaceable at home. The end tank and cooler is available as a separate replaceable part and the end tank just crimps in place with tabs that are easily un-bent and re-crimped with simple pliers.
    capn's Avatar
    Feb 2004
    216
    Quote Originally Posted by bbob
    what i mean by internal leak is that i can not visibly see the leak but i can see where it is spraying and getting other parts wet, like its in the middle of the radiator
    80greyhound is offline Cadillac Owners Member
    May 2003
    4
    Hate to go off subject here, am I to assume the '98 Eldo with a 4.6 has no reserve tank for the radiator? All I can find is the main radiator cap. Do I just add the coolant straight into that?
    Lawrence's Avatar
    Oct 2003
    Ohio
    334
    That's right. 1 1/2-2"s below the neck.
  12. Remove Advertisements
