Engine removal
Results 1 to 10 of 10
Northstar Engines and System Technical Discussion Discussion, Engine removal in Cadillac Engine Discussion; I have a 97 Seville with all the classic signs of a head gasket, did all the standard checks (new ...
    jholland is offline Cadillac Owners Member
    Automobile(s): '97 Seville '76 Eldorado
    Apr 2005
    67
    Engine removal
    I have a 97 Seville with all the classic signs of a head gasket, did all the standard checks (new GM thermostat water, pump,etc.). I have lengthy experience with engines that come out the top, non on engines that come out the bottom. To make matters worse I don't have a lift. My only solution appears to be to drop the cradle and raise the car off the engine. Do I have a prayer of doing this and is there a procedure? IS there any way to get the engine out the top.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: Engine removal
    You CAN get the motor out of the top, but it's reccomended to drop the cradle for a reason... If you've got a decent engine lift you can lift the car that way.
    white97deville is offline Cadillac Owners Member
    Automobile(s): '97 Deville
    Mar 2005
    Dallas, TX
    81
    Re: Engine removal
    If you have space it was fairly easy to remove the cradle from the bottom and lift the body. I borrowed a dolly from work to drop the cradle on and just rolled it out from under the car.
    Mar 2005
    Dallas, TX
    81
    Re: Engine removal
    Ooops! That pic came out big. Don't know why or how to resize. I'll delete it if it bothers anyone.
    Apr 2005
    67
    Re: Engine removal
    Thanks for the pic. I think I'll go out the bottom. How tough was it to repair the headgasket?
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: Engine removal
    jholland,
    You had two identical threads. On the other thread I suggested you look at the N* head gasket repair in tech tips for a lot of info. Did you look at that? Lists tools needed and gives a bunch of tips.
    Sep 2003
    Arizona
    3,531
    Re: Engine removal
    white97deville,
    That's a much better pic than I posted. Can you add that to the N* head gasket repair thread?
    Mar 2005
    Dallas, TX
    81
    Re: Engine removal
    Quote Originally Posted by zonie77 View Post
    white97deville,
    Done.
    Apr 2005
    67
    Re: Engine removal
    Got the engine out. Two lower head bolts on cylinder 4 were loose(stripped) the other bolts had anti sieze compound or something and came out fine. Is this an indication that this engine has had timeserts. Any way to tell?
    Sep 2003
    Arizona
    3,531
    Re: Engine removal
    If it had been timeserted you would see a steel ring in the bolt hole. I doubt it has been timeserted before. You should do all 20 holes now.
    The bolts have a sealant on them from the factory. Replace the bolts, they come with the factory head gaskets.
  13. Remove Advertisements
