Need help with codes
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Need help with codes in Cadillac Engine Discussion; I have 2 codes in History on my 98 Deville with 65,000 miles on it they are IRC B1771 IRC ...
    PhantomCadillac is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DTS
    Feb 2004
    Florida
    58
    186
    IRC B1771
    IRC U1255
    and then it comes up with
    PCM?
    Lawrence's Avatar
    Lawrence is offline Cadillac Owners Fanatic
    Oct 2003
    Ohio
    334
    Re: Need help with codes
    Might help until someone can help with the cause. The PCM? is normal. You might try to reset first and see if they come back. Not sure exactly how it is done but can be done in the DIC. You could also try disconnecting then reconnecting the battery. Of course that will give you a code too which will go away after 40 starts. Has any work been done on the car recently?
    Body code B1171 - Internal SDM Failure
    Network Code U1255 - Serial Data Line Malfunction
    Feb 2004
    Florida
    58
    186
    Before I bought it in Dec of 2003 it had the waterpump replaced.
    Feb 2004
    Florida
    58
    186
    Any Idea what those codes mean? Thanks for your help. I really like the Deville it is the best car I have owned to date. And I have own quite a few cars in my time.
  7. Remove Advertisements
