Tips for replacing Crankshaft Position Sensors
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Tips for replacing Crankshaft Position Sensors in Cadillac Engine Discussion; My 2000 Eldorado T/C has recently started stalling a lot once or twice a day. The code given indicates I ...
    Devast is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2006
    15
    QuestionTips for replacing Crankshaft Position Sensors
    My 2000 Eldorado T/C has recently started stalling a lot once or twice a day. The code given indicates I have two bad CPS. I have bought replacements and am going to try to change them out. From this board I have gotten the impression that this is a DIY job. I crawled under the car to check it out and I have a couple of questions before I start.
    1. From posts here I understand you can access these by removing the oil filter mounting hardware. Is this correct? I cannot see the sensors as it is.
    2. From beneath the car I can only see one mounting screw for this piece (oil filter mount). I presume there is another one higher up but I cant see it. Am I correct and how difficult is it to get to?
    3. My understanding is that the Black sensor is the bottom one and the Gray is the upper... correct?
    4. I am maybe slightly better than average with cars, not an expert by any means. I have replaced these sensors on my old BMW so Im a little familiar with the process, but are there any problems or pitfalls I should look out for? If you think I should just pay someone to do it feel free to say so.
    I appreciate any and all advice.
    Thanks, Devast.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Re: Tips for replacing Crankshaft Position Sensors
    These were provided to me by other members and seem to prove very useful.
    http://webspundesigns.com/uploads/Ca...tPosition1.pdf
    I threw them up on the web to share.
    Thanks guys
    AlBundy's Avatar
    AlBundy is offline Cadillac Owners Master
    Automobile(s): 1996 Eldorado Sport Coupe, 2009 Black Navigator
    Jul 2005
    Chicago
    41
    5,016
    Quote Originally Posted by codewize View Post
    http://webspundesigns.com/uploads/Ca...s/LHengine.jpg
    Thanks guys
    Dame Codewize those are some excellent drawing. I also intend to do the same thanks.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    The credit should go to MashBill and JimD
    I will accept some rep though for posting them
    Sep 2006
    15
    Thanks. Those will be very helpful to anyone doing this job. I did it yesterday. Not so tough.
    If you think you want to try this job but you are kind of a novice like me... Go for it. It's an easy job. Kind of a tight fit but I'm a pretty big guy and I got it done in a little over an hour.
    Devast
  8. Remove Advertisements
