a lil help please
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
Northstar Engines and System Technical Discussion Discussion, a lil help please in Cadillac Engine Discussion; limps at start up and smokes 20 secs later stops limping and smoke goes away Please help what could be ...
    molotovman5000 is offline Cadillac Owners Fanatic
    Automobile(s): 01 deville
    Aug 2005
    Arizona
    30
    330
    a lil help please
    limps at start up and smokes 20 secs later stops limping and smoke goes away Please help what could be the problem
    plugs, wires, coils??? the only code i get is the 0300 (misfire)
    BTW 97 Deville 275 HP engine
    thu's Avatar
    thu
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    Re: a lil help please
    Misfire? Hmmm...I wonder if that's an indication of the problem you're seeing?
    Kinda sounds like injector is leaking at shutdown, filling a cylinder with fuel. When you fire it up, it runs really rich until they extra fuel is all gone. Might be where that misfire code is coming from.
    68
    81,938
    Hard to tell from those pics, but the smoke appears to be black. Like Thu said, check the injectors as well as the FPR. Have you had the fuel rail recall done? How many miles on it? Are the plugs & wires original?
    wydopnthrtl's Avatar
    wydopnthrtl is offline Cadillac Owners Fanatic
    Jan 2006
    SE Michigan
    198
    It is hard to tell from the pics. But if the smoke is black or mostly black-ish blue? It's fuel related.
    If it's pure white it's either water getting into the cylinder after shut down or possibly oil getting in there. What does the smoke smell like? Fuel, burnt oil, or burnt antifreeze?
    The symptoms you describe sounds EXACTLY like a fliud leaking into the cylinder after shut down. Does it get worse the longer the motor is off?
    Rich
    Aug 2005
    Arizona
    30
    330
    no if i leave the car off for an hour or a day it smokes the same, im positive its not antifrezee, i think it smells like fuel, i changed the plugs today with the AC delco ones and still smokes, not as much though, the wires are good.
    the cars gots 91K miles. it gots the stock fuel rail, the car is a restored salvage so i think the recall is void
    68
    81,938
    If it looks like fuel and smells like fuel, it probably is. Since it only runs rough and smokes for a few seconds after start up, I'm with Thu. Sounds like an injector leaking fuel into the cylinder and burning off after start up. I don't know how much it would take, but if enough leaks in the cylinder and you crank it over, you stand the chance of hydrolocking the engine. Then you will have BIG problems. Get this taken care of quickly. If you pulled the old plugs and paid attention to them, the offending injector should be pretty obvious as that plug would be carbon fouled. In any case you will have to pull the fuel rail, so pull the rail with the injectors attached, then turn the key on (do not crank) to pressurize the fuel rail and see which, if any leak. This might be a good time to purchase a stainless steel fuel rail and install it. It may be expensive but it is cheaper than the alternative.
    '98 Eldorado
    http://i7.photobucket.com/albums/y29...rbequeTime.jpg
    http://i7.photobucket.com/albums/y29...et/Endgame.jpg
    Aug 2005
    Arizona
    30
    330
    ^^^^ ouch that sucks, hope that dosent happen to mine
    68
    81,938
    Quote Originally Posted by molotovman5000 View Post
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    The fuel rail is a safety recall. I think it's honored even with a salvage title.
    Aug 2005
    Arizona
    30
    330
    so do i just go to the dealer, and tell them "im here for the fuel rail recall" lol
    68
    81,938
    Yup, it includes '95 - '97 Northstars.
    Aug 2005
    Arizona
    30
    330
    cool thanks
    Sep 2003
    Arizona
    3,531
    I'd call them and give them the vin #. THey can verify if it qualify's and if they have the part in stock.
  16. #14
    Aug 2005
    Arizona
    30
    330
    UPDATE!!! Changed plugs (ac delco), wires, air filter, oil, oil filter, and the car stoped smoking, but this morning the dash read coolant level low, first think in my mind was F**K BHG!!, topped off the coolant, drove it for 60 miles, came back, and the coolant was still in the same place i toped it off, and there is no white smoke and the car was runing fine engine temps (206-217)
    I think the previous owners had the fuel rail replaced does this look like the original?
    yeah a lil dirty lol
  17. #15
    Feb 2004
    FL
    2,250
    That's the stainless steel rail
  18. Remove Advertisements
