quick engine question
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, quick engine question in Cadillac Engine Discussion; i know my 95 eldo had a recall on the fuel system hose and pipes, and they were originally nylon ...
    CaddieMan709 is offline Cadillac Owners Member
    Automobile(s): 95 Eldorado
    Sep 2006
    IOWA
    82
    i know my 95 eldo had a recall on the fuel system hose and pipes, and they were originally nylon tubing and they would replace it with stainless steal and i took the beauty cover off my engine to see if my car ever was fixed from the previous owner and i saw a stainless steal pipe that comes around the back of the engine and goes in a |_| shape around the side of the engine, the pipe says ac delco on it, is that the fuel line because i could fine no other pipes?
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: quick engine question
    The fuel rail was the part that had a recall. And that is the part that is on top of both sides of the engine. You should be able to see it. It's what the fuel injectors are connected to.
