Help with Check engine light and pcm codes!!
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Help with Check engine light and pcm codes!! in Cadillac Engine Discussion; Well recently my "check engine soon" light came on so I decided to pull the codes. I came up with ...
    CaddieDeville is offline Cadillac Owners Member
    Automobile(s): 99' cadillac deville
    Jul 2005
    Florida
    29
    33
    Well recently my "check engine soon" light came on so I decided to pull the codes. I came up with a few, they are as follows:
    History PCM P0603
    History PCM P0741
    History PCM P1520
    I would like to know what the codes mean and how I can resolve them. And If theirs something I am missing please inform me of them. I have a 99' Deville with 70,000 miles thnx!
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,284
    Re: Help with Check engine light and pcm codes!!
    Quote Originally Posted by CaddieDeville View Post
    History PCM P0603
    History PCM P0741
    History PCM P1520
    http://www.obdii.com/codes.asp
    Look'em up.
    Jul 2005
    Florida
    29
    33
    Well I've figured out what the codes were nothing to worry about except for P1520- Transmission Range Switch Circuit, Can anyone explain what this means and how I can fix it?>??
    69
    82,269
    I am not sure what that one is, but since it is historical, clear it and see if it returns.
    Feb 2004
    FL
    2,250
    The transmission range switch is the little black box sitting on your tranny shift arm. I don't think it's a problem not having one operating properly, because inside the transmission is another set of switches as a backup. However, if those fail you'll start to drop out of gears, which isn't fun
  8. Remove Advertisements
