How to calculate HP to weight ratio?
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, How to calculate HP to weight ratio? in Cadillac Engine Discussion; My Deville is right around 4,000 lbs.(I think) and 0-60 is about 7 seconds, obviously the more weight I add ...
    weister42 is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville Sedan
    Feb 2005
    897
    My Deville is right around 4,000 lbs.(I think) and 0-60 is about 7 seconds, obviously the more weight I add the slower it gets. So, how much speed am I losing for every 100 pound added load? Things like subwoofers, extra batteries, junk in the trunk, passengers...etc.
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    31
    3,703
    Re: How to calculate HP to weight ratio?
    Well, I don't know how much this will help, but they say that for every 100lbs of weight added, you loose loose 1/10 in the 1/4miles and vice versa. I would say that it would probably apply in the same fassion to your 0-60 time. Maybe not exactly, but you will definitely get slower.
    Elmer Fudd is offline Cadillac Owners Fanatic
    Automobile(s): 99 Deville Concours
    Jul 2006
    Tuscaloosa, Al.
    60
    199
    Physics 101:
    F=MA therefore A=F/M Which says increase mass by 10%, reduces acceleration by 10%. So 100 more pounds is 1/40, therefore you reduce your acceleration by 1/40. Now then we also know:
    D=1/2AT^2
    Rearranging:
    Time = square root (2D/A)
    Just for fun, lets say you car accelerates at 32 ft/sec^2 at 4000 pounds. At 4100 it would be 31.2 ft/sec. So your two 1/4 miles times are:
    @32ft/sec^2 = 9.08 sec
    @31.2ft/sec^s = 9.20 sec
    But it is not that simple. That assumes a frictionless situation, which is not so in the real world. Extra weight means extra friction as well, so the actual increase would be somewhat greater, though not a lot, (due to rolling resistance on the tires, bearings etc.) Air resistance would be unchanged.
    So I cannot disagre with Danbucs estimate of 1/10 sec in the quarter mile. Perhaps a bit more.
    Feb 2004
    FL
    2,250
    Quote Originally Posted by Elmer Fudd View Post
    Well not only that, it's assuming a linear acceleration, which is not the case. At best you'd probably see 0.5 G's at launch, and as your speed increases, your acceleration will decrease. This is mostly due to gear changes, partly due to air (and other) friction.
    The 10th/100 rule is pretty standard though, and that does carry over to the 60mph pretty consistantly. If your 1/4 drops by 0.1, your 60mph will drop by about 0.1. This won't apply to really fast or really slow cars.
    Jul 2006
    Tuscaloosa, Al.
    60
    199
    Actually I assumed constant torque, I guess. That would translate into constant acceleration. Torque also varies of course, but if you look at it in terms of % change, it should still apply within reason.
    Looked good anyway............
    Elmer...professional engineer...but clearly NOT automotive...
    Feb 2005
    897
    So say if my stereo system is about 300 pounds, that means I would loose about .3 seconds on 0-60?
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    And remember that 1 pound of sprung weight is equal to 4 pounds of un-sprung weight, or so I'm told.
    Why the hell would you put a 300 pound stereo in a car then worry about performance. Heck I've decided not to put a top on my car because I don't want to add the weight or the drag. The spoiler is a must and doesn't weight that much.
    Feb 2004
    FL
    2,250
    Quote Originally Posted by weister42 View Post
    Yes. Similarly, if you have a cow in the front seat.... you'll lose a second.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    ROFL
    Quote Originally Posted by eldorado1 View Post
    Mark Bunds's Avatar
    Mark Bunds is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Seville STS
    Jul 2005
    Baytown, Texas
    56
    187
    So, as the weight approaches zero, my acceleration approaches infinity?
    Feb 2004
    FL
    2,250
    Quote Originally Posted by Mark Bunds View Post
    Yes, but...
    Once you start approaching C (the speed of light), relativistic theory starts to come into play and you start gaining mass (weight), so your acceleration will come back down.
  14. Remove Advertisements
