What Year NSs Fit a '99 Deville? Need Help
Results 1 to 9 of 9
Northstar Engines and System Technical Discussion Discussion, What Year NSs Fit a '99 Deville? Need Help in Cadillac Engine Discussion; I have a '99 Deville DeElegance and my dealer has a NS that had only 2k miles before they had ...
    Quadrasteer is offline Cadillac Owners Fanatic
    167
    I have a '99 Deville DeElegance and my dealer has a NS that had only 2k miles before they had to fix a casting pinhole in the coolant jacket. They ended up putting a new engine in and they have the old one laying around. The problem is, he said that a one piece coolant manifold engine (throttle body housing is part of the manifold) will not fit my 2 piece type engine. Is that true? I'll try and find out what year and model car that engine came out of.
    68
    81,746
    Re: What Year NSs Fit a '99 Deville? Need Help
    '95 - '99 is compatable for your car.
    167
    The dealer thinks the engine he has is out of a 2000 seville. What would I need to do to make it compatible?
  5. #4
    68
    81,746
    My guess would a new PCM and wiring harness for starters (if possible).
  6. #5
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    the old guru claimed that this conversion was "impractical" and more trouble than it is worth.
  7. #6
    167
    Does anyone know exactly what needs to be done or exactly what the differences are? I may be able to get the parts cheap. I would also like to understand why the block and heads can't be used and all the stuff from the old motor put back on. Is there a bolt up issue?
  8. #7
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    The sensors are different, both electronically and physically. The"timing wheel" in the block is different.
    Someone did it a year or more ago but it was a fair amount of custom work. Not something a shop would do. If you do fabrication it might be worth it but it is not a bolt in. The block is slightly different.
  9. #8
    Feb 2004
    FL
    2,250
    Quote Originally Posted by Quadrasteer View Post
    Crank has a different reluctor wheel, and different crank sensors. Intake ports are set up differently. 2000 uses coil on plug ignition (requires all new computer to run), and a few other things I'm forgetting.
  10. #9
    167
    I guess it's a no go . Thanks for the input. Just in case anyone needs one, the dealer still has it, just post or PM me. Anybody want to buy a '99 Deville D'Elegance with a sunroof and 103K, only needs headgasket!!
  11. Remove Advertisements
