Northstar Oil Usage - Page 2
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 83
Like Tree2Likes
Northstar Engines and System Technical Discussion Discussion, Northstar Oil Usage in Cadillac Engine Discussion; one thing i don't see mentioned here is that the n* uses low tension rings. (mostly used in race engines) ...
  1. #16
    xxcaddytech is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2006
    39
    Re: Northstar Oil Usage
    one thing i don't see mentioned here is that the n* uses low tension rings. (mostly used in race engines) it does mean oil consumption BUT it frees up horsepower. and saves the precious cross hatch pattern.. that is tha main reason we see almost no ridge when torn down. its harder to wear out if no pressure is being applied and a thin coat of oil is inbetween the surfaces.. btw how come lexus can build a 24v motors with none of these problems and deadly reliabliity and gm can't?? --i own both--
  2. #17
    hkaiman is offline Cadillac Owners Member
    Apr 2008
    6
    does anyone know of any additives for the oil to help burn off the carbon from the rings?? I hear that the carbon buildup can cause the oil consumption.
  3. #18
    krimson_cardnal's Avatar
    krimson_cardnal is offline Cadillac Owners Enthusiast
    Automobile(s): 96DeVille
    Aug 2005
    NY Capitol District
    69
    962
    Periodic WOT added once a month on a quiet open stretch of highway. K_C
  5. #19
    Apr 2008
    6
    what can I add to the oil to help burn off the carbon on the rings?? I head this helps stop the oil consumption.
  6. #20
    68
    81,917
    Go to the top left of this page. Click on Technical Archives and read up. Nothing you can put in the oil will help.
  7. #21
    Aug 2005
    NY Capitol District
    69
    962
  8. #22
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,891
    hkaiman, .......If you're bound and determined to pour something liquid into your engine one way or another, first Google " top tier gasoline " and read up on Chevron's fuel additive/engine cleaner TECHRON and the gasolines which contain it. Also, follow Ranger's advice and go to the upper black section of this page, bottom left corner, and read the technical Archive, particularly the section on oil consumption. If you still haven't had enough, start going back through this Forum, page by page, and open threads of interest.
  9. #23
    Aug 2005
    NY Capitol District
    69
    962
    As has been said check the Archive.
    Think of the NorthStar as a cardiovascular system. Put the correct amounts of the right thing in it and exercise to raise the heart rate. It's like the current Cadillac ads say, when you turn your engine on does it return the favor. Raising the heart rate - both yours and the engines is one of the better things you can do for both. WOT once a month keeps you and your NorthStar alive and well. It certainly helps keep the dreaded carbon levels down and gets the rings spinning. The use of any Top Tier fuel will also help keep the gunk out of the air ways and other lost corners allowing a deep breath of fresh air.
    Dr. K_C
  10. #24
    Apr 2008
    6
    thanks Dr. K_C that was a neat way of putting things.
    I will do that..
  11. #25
    JohnnyO's Avatar
    JohnnyO is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado, '04 DeVille
    Nov 2003
    Pittsburgh, PA
    194
    2000 and newer N*s tend to use less oil than the earlier ones. According to a TSB I had from GM, it is not necessary to add oil unless or until the Low Oil light comes on unless you are going to race it. As mentioned, when changing the oil only add 7 quarts with filter and exercise it once in a while. My mother's '99 burns oil like a two-stroke, my dad's '04 doesn't burn a drop. On the '99 I switched to Valvoline Max Life (although the car does not have high miles on it) and it burns somewhat less oil.
  12. #26
    Destroyer is offline Awaiting Email Confirmation
    Automobile(s): '67 Cutlass,'92 Z28, '12 Crosstour, '12 Cube,00 GMC 4500
    Oct 2003
    Florida
    45
    6,165
    Quote Originally Posted by Buddy94 View Post
    Hey,
    I am looking for some information on the oil usage of the northstar engine. I am looking at a 2000 STS. If I purchase it, it will be my second Caddy. I have heard that the northstar engine requires a quart of oil every 1400 miles. For the past six years, I have driven my 94 Caddy with the 4.9L from Arizona to Florida with no loss of oil. Does anyone out there have a northstar engine? If so, can you share some information on this topic?
    Buddy94
    I put 10k miles on my '98 Deville, had 88k when I bought it and 98k when I sold it with a blown head gasket(fully disclosed to new owner). It burned a quart of oil about every 3 weeks. I wrote on here about it and found that oil consumption is another bad trait of the Northstar. Basically the Northstar HATES its fluids and spits 'em out one way or another. Oh yeah, they like to leak oil from the bottom too!.
  13. #27
    Apr 2008
    6
    Quote Originally Posted by Destroyer View Post
    I have a 2000 Deville with Northstar and 70000 miles. It is really using the oil now. It just seems to dissappear. No smoke, no drip. nothing wet in engine.
    Just vanishes. I have to add a quart about every 800 to 1000 miles.
    I have been finding out this is very common for the engine. Wish I knew that before I bought it....
    hkaiman
  14. #28
    Feb 2006
    55,891
    For the flip side of Destroyer's oil coin, my 02 STS uses a quart every 3,500 - 4,000 miles, leaks not one drop, and has not received one ounce of DEXCOOL since 11-21-05, and that includes after a coolant drain and refill last September. I change the oil and filter, fill to halfway up the dipstick hashmark, and that's where it stays for 3 - 5 months.
    Lumping all Northstars into the same unhealthy group is patently wrong. Some are mechanically perfect, most are in the middle of the curve, and some are just plain awful. You never hear from the first two groups in a forum: you only get some of the last group represented by people searching for answers.
    It has been posted in the performance threads several times by different posters, but I'll post it again: If you try to keep a N* filled to the top of the dipstick hashmark the engine will rapidly get rid of that half quart. RAPIDLY. Run it between the bottom and middle of the hashmark.
  15. #29
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,704
    Oil is cheap - I don't mind adding it once in awhile - what I do mind are leaks that leave a mess everywhere I go, like I had before I did my HG project and also changed all seals and gaskets, except for the 1/2 case.
  16. #30
    68
    81,917
    Quote Originally Posted by hkaiman View Post
    hkaiman
    You wouldn't have bought it just because it uses a little oil? Oil useage is not such a bad thing when you understand it. Go to the top left of this page. Click on Technical Archives and read up on it.
  17. Remove Advertisements
