Help installing camshafts
Results 1 to 14 of 14
Northstar Engines and System Technical Discussion Discussion, Help installing camshafts in Cadillac Engine Discussion; Hello Everyone I have just recently bought a 1996 Seville STS off ebay for $1200.00. I did not do my ...
    brown1904 is offline Cadillac Owners Member
    Automobile(s): 1996 seville sts
    Aug 2006
    tennessee
    47
    25
    Hello Everyone I have just recently bought a 1996 Seville STS off ebay for $1200.00. I did not do my homework before buying,seller said engine had blown headgasket. Engine was already torn apart. I am trying to stay on a low budget with this car, what I would like to know is 1) what are the torque specs and the sequence for torquing them are? 2) what is the proper way to tighten down the cams, and the torque values for them? Any info would be greatly apprec.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: Help installing camshafts
    buy a factory service manual for the car your gonna need it for that porject....
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    You really should buy the FSM. There is enough to reference that it's pretty hard for someone to give you everything you'll need. Check EBAY. We used manuals a year off and they covered everything we needed.
    I think 96-98 are very similar. Someone who knows for sure can chime in.
    Depending on where you live the public library may have Alldata access. I know Phoenix and San Diego do.
    Some things have been covered in threads. Cam timing and head torque among them. You can search and find those threads.
    You probably do not have to do anything with the valves or cams. Leave the heads alone unless you see something obvious. The N* has really good heads, they don't warp or burn valves.
    Aug 2006
    tennessee
    47
    25
    Zonie77 Thanks for responding I was hoping to hear from you,I have read a lot of your threads. Do you think the heads need to be checked for cracks and milled for warpage? The gasket blew on the back side between the first and second cyl from left to right. Thanks
    Sep 2003
    Arizona
    3,531
    As I said, unless you see something obvious they should be OK. The majority of guys who did their own did not do anything to the heads except clean the gasket surfaces.
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,284
    Don't use Scotch Brite pads for anything to do with machinery. They are the worst possible contamination.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Quote Originally Posted by brown1904 View Post
    I'd just check the gasket mating surface with a good straightedge and run with it.
    Aug 2006
    tennessee
    47
    25
    Does anyone know the sequence to torque the heads to?
    Aug 2003
    Albuquerque, NM
    29
    7,971
    This is why an FSM can come in handy... if nobody else replies I will take a look tomorrow (although mine's a 95 there *should* not be a difference,) my info is at my friends house/garage.
    Sep 2003
    Arizona
    3,531
    The FSM says 22ft/lb + 60deg + 60deg + 60deg.
    That's 22ft/lbs plus 180 degrees in 3 steps. I think that was updated to a slightly higher figure though.
    Mark the bolts at the 22 ft/lb step so you can verify the turns. Use a sharpie/marker.
    Aug 2006
    tennessee
    47
    25
    SmileRe: Help installing camshafts
    Thanks for your help!!!!!
    Sep 2003
    Arizona
    3,531
    Keep us updated of your progress. Where are you located in TN?
    Aug 2006
    tennessee
    47
    25
    I live about 30 min North of Nashville neaKy line off of I-65. I have a tool & die maker from my work coming 9/5/06 to install inserts. Will keep you guys posted.
  16. #14
    Sep 2003
    Arizona
    3,531
    I did Power Tour last year, stopped in Nashville. Nice country.
    We were gonna go back there this summer but lotta things came up.
  17. Remove Advertisements
