Cylinder pressure test for blown head gasket??
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Cylinder pressure test for blown head gasket?? in Cadillac Engine Discussion; I need your help in understanding just what a cylinder pressure test is. I am looking at a 2001 SLS ...
    Windrider is offline Cadillac Owners Member
    Automobile(s): 98-SLS, 01-SLS
    Jul 2005
    Near Richmond, Va
    74
    29
    I need your help in understanding just what a cylinder pressure test is. I am looking at a 2001 SLS and want to have this test done along with other cooling system checks before I go too far. I am super sensitive because my 98 SLS is toast because of a blown head gasket. Ok to my question. Is the cylinder pressure test the one that tests the combustion pressure by using a tool that replaces the spark plug and you run the engine, record the value and then go on to the next cylinder until done then check the values against the factory spec? Or is it a test where the spark plug is replaced by a tool to which compressed air can be added to the cylinder and then checked for loss of pressure over a time period.
    Also what should I expect to pay for this test and does it make sense for me to get the tool and do it myself?
    Thanks for your help!!
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,263
    Re: Cylinder pressure test for blown head gasket??
    You put air into each cylinder through the spark plug holes and look for air leakage into the cooling system. If you don't have the tools or experience it is best left to a good shop. About an hours labor.
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,951
    You should also know that Cadillac revised the head bolts for the 2000-up Northstars to improve the head gasket reliability.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Windrider,
    Your first description is a compression test. You do not run the engine but crank it with the starter motor.
    The second is the cylinder pressure test and it is the more accurate (by far).
  7. Remove Advertisements
