My northstar went south
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, My northstar went south in Cadillac Engine Discussion; hello to all, this week i picked up a 97 deville for close to nothing under 2000.00 to be exact,the ...
    sscapricewagon's Avatar
    sscapricewagon is offline Cadillac Owners Member
    Automobile(s): deville
    Apr 2006
    south florida
    5
    CoolMy northstar went south
    hello to all, this week i picked up a 97 deville for close to nothing under 2000.00 to be exact,the trouble is it has engine trouble i think it's the head gasket i have a slight sign of water in the motor oil.the engine is missing and pop's as if it were out of timing.does anyone have any ideas as to how to check for headgasket or cracked block besides checking water level ,and do you think it would be more cost effective to geat a new engine say from jasper, or do the head gasket and call it a day. the car is well worth repairing thanks in advance for any reply
    68
    81,928
    Re: My northstar went south
    Cracked block is unlikely. Bad head gaskets on a Northstar usually won't put coolant in the oil. Use the search feature. How to check for a bad head gasket has been discussed many times. Post back if you have questions and with the results. Are you using coolant?
    Head gasket job is around $3000. Be sure they Timesert all twenty head bolt holes if you go that route. A new engine must be twice that amount, at least.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Apr 2006
    south florida
    5
    HaHa beating a dead horse thats funny!
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    and remarkably appropriate for the subject matter
  8. Remove Advertisements
