turn signal problem ('94 STS)
Closed Thread
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, turn signal problem ('94 STS) in Cadillac Engine Discussion; Both left and right turn signals have stopped working, they seem to try to work every once in a while. ...
    Reactor is offline Cadillac Owners Member
    Automobile(s): '94 STS, '94 SLS, '72 couple deville
    Mar 2004
    74
    Unhappyturn signal problem ('94 STS)
    Emergency flashers works.
    Manual states there are 2 flashers, I can only see one silver can flasher under the dash, (replaced it, no change). Is 1 flasher for the emergency lights, and the other for the turn signals?
    Where is the other flasher located?
    I supected the turn signal switch, changed it, ( what a job), but no change.
    Please Help
    Thanks
    Quick reply to this message Reply
    Mar 2004
    74
    Re: turn signal problem ('94 STS)
    Since I did not get any replies, I went to Ask.com.
    I was sent in the direction of the left side of the steering column.
    After removing the kick panel, the knee panel, and a metal plate covering the
    steering column.
    I did find the turn signal flasher relay hidden, mounted with a clip on the
    back side of the left none removable knee panel, behind the lip edge of the panel, it is black and can not be seen if you do not know that it is there.
    I replaced it and that corrected the problem.
    FYI
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    prob didnt get any hits b/c this is technical discussion about the N* not about electrical, this should of been posted in the electrical section or at least the section of which car you own.
    94CaddyConcours's Avatar
    94CaddyConcours is offline Cadillac Owners Fanatic
    Automobile(s): 1994 CADILLAC DEVILLE CONCOURS, 350ZR
    Jul 2004
    LONG BEACH KALIFORNIA, HOUSTON
    444
    I dont even bother at mind anymore. My left brake light doesnt lit and the buld are not burnt. Also ther left flasher flash faster than the right when the headling is on and right is faster when headlight is off. Oh well whose care.
    urbanski is offline Cadillac Owners 10000+ Posts
    Automobile(s): 05 CTS-V
    Mar 2003
    San 'tone, TX
    23,163
    Quote Originally Posted by Reactor View Post
    steering column.
    FYI
    glad you found your answer.
    this was not the proper forum for your question, which is why nobody replied.
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
  8. Remove Advertisements
Closed Thread
