Runnin without o2 fuses in
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Runnin without o2 fuses in in Cadillac Engine Discussion; I've been driven my car 96 devile without the 02 sen. She seems to run better but was wondering about ...
    unruley247 is offline Cadillac Owners Fanatic
    Automobile(s): 02 300m special,04 Intrepid, 07 Z06 and a 05 Yukon
    104
    I've been driven my car 96 devile without the 02 sen. She seems to run better but was wondering about if any damage I might cause
    69
    82,287
    Re: Runnin without o2 fuses in
    I am sure that the PCM wil substitute a default value to keep the car running, but it may not be the optimum value. One thought that comes to mind it possible damage to the CAT if you are running to rich.
    Feb 2004
    FL
    2,250
    Are you driving without an oxygen sensor, or without the oxygen sensor's fuses? The fuses don't make much difference... They heat up the o2 quickly so the computer can enter closed loop shortly after startup. At worst you'll get worse gas mileage. Once they're warmed up, they'll act normally.
