Thoughts on G-Tech Pro
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Thoughts on G-Tech Pro in Cadillac Engine Discussion; So I ran the DTS with the G-Tech Pro today. I found out while setting it up that the car ...
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    So I ran the DTS with the G-Tech Pro today. I found out while setting it up that the car won't allow you to tach over 4k in park. I found that interesting.
    Anyway I was wondering what people thought of these things and how accurate they are.
    Anyone?
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    Re: Thoughts on G-Tech Pro
    OK I'll give up the goods. Since there was an issue marking the 4k point we marked 3k and 2k.
    I ran the car and the G-Tech reported
    246 HP
    14.73 QT
    Tourque was not measured for some reason.
    The unit was not mine so I don't know what other info was availabe. I was driving and didn't know what other info to ask for. I'm sure the run was saved if anyone cares.
    1997seville's Avatar
    1997seville is offline Cadillac Owners Fanatic
    Automobile(s): 97 Seville SLS
    May 2006
    Aberdeen, MD
    44
    170
    All the n*s are rev limited at 4k. You can calibrate the G-Tech while moving, you dont need to do it in park. It says that in the manual. Just put your car in 1st gear so you can hold the RPM's at 4K for the calibration.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    Ahh ok. Well this was my daughters boyfriends G-Tech so I didn't get to read the manual. I guess he didn't bother.
    Do those numbers seem squewed?
    Quote Originally Posted by 1997seville View Post
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    yea they do G-Techs are only as good as the calibration.
    My 97 ETC which weighs alot less has a full cat back custom exhaust and im one hell of a driver has only pulled 14.5 at my LOWEST time usually im around 14.7-14.9
    in english 14.7 for a stock DTS possible but without corsa and a few other mods, its unlikly same with the HP rating of 246, again unless you have a corsa exhaust
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    No mods yet. I do have a few tricks up my sleeve and some mods planned. Corsa being one of them. I also am a well trained drag driver. I used to clock such low reactions times I had people begging me to drive their cars. I wish I could find an old time slip laying around.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    I don't trust G Tech type accelerometers. I'll take a timeslip's word for it, but not that little box. That said, they're usually within a few tenths.
    Blown Z's Avatar
    Blown Z is offline Cadillac Owners Fanatic
    Mar 2006
    IL
    110
    I like the Escort G-Timers much better. I have tried both the G-Tech and the G-Timer and the G-Timer has been more consistent and accurate.
  11. Remove Advertisements
