ticking throttle
Results 1 to 13 of 13
Northstar Engines and System Technical Discussion Discussion, ticking throttle in Cadillac Engine Discussion; I don't know if this has been addressed before, but I'm stumped. Sometimes(not all) when I shut off the engine ...
    jgreen is offline Cadillac Owners Member
    Apr 2005
    22
    ticking throttle
    I don't know if this has been addressed before, but I'm stumped. Sometimes(not all) when I shut off the engine in my 95 Seville the throttle cable will click several times. I can see it happening.
    No codes are set. The TP sensor at idle is .78V, throttle angle is 4 to 5 degrees. Could I have a hung up ISC valve?
    Can anyone suggest possible causes?
    Thanks
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    Re: ticking throttle
    I think the 95 still has an idle speed control motor, try searching for that or "ISC motor"
    68
    82,076
    ISC motor is failing.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Mine's been doing that for about a year and a half now. ISC hasn't gone out on me yet...
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Yup for sure ISC. It's the little thing that look like a solenoid that the throttle rests on mounted to the throttle body. It has a threaded rod that pushes out to maintain idle if the idle drops and to produce the step up idle during cold starts.
    If you replace this your self there is a sequence you must perform to calibrate it. You can't just take old off and put new on. Also note that this part will cost you around $200, if I remember correctly.
    Both of you should be careful with this. I had mine one day all of a sudden throw WOT while I was decelerating coming into a city road. I also knew it was bad and kept letting it go. Get it fixed. You'll save a lot of gas and it'll be safer.
    CadiJeff's Avatar
    Feb 2004
    Nerk,Ohio
    36
    1,072
    $200?!?! not US dollars you suouldn't pay more than $100 at any parts source got an oem last year from dealer for $78.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Really? I think the dealer charged me $180 for my 89 STS.
    Quote Originally Posted by CadiJeff
    Apr 2005
    22
    Thanks for all the help guys. You're right on the money. It was the ISC motor. $65.00 at Rock Auto, on line.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Sweet. I guess I paid top dollar from the dealer. Maybe that was installed? It's been a whiel so I don't really remember.
    Quote Originally Posted by jgreen
    2dedge is offline Cadillac Owners Member
    Dec 2005
    23
    What is the procedure for calibrating?
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Ouch, I'll have to look. It's something like at idle you push the rod back into the unit as far as it will go then you unplug it at that point. Then you turn the end in or out to get the idle to 500 RPM. They you plug it back in.
    I wouldn't trust this info until I or someone verifies it. But it's something to that effect.
    Look here
    AND
    Read this PDF
    68
    82,076
    Press on the plunger til it retracts. When it bottoms out, unplug it. RPM should be about 450 (maybe even stalled). Release the plunger and adjust to a .030 gap. Reinstall the electrical connector.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Yeah yeah, that's it. I knew it was pretty easy.
  16. Remove Advertisements
