99 seville sls
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, 99 seville sls in Cadillac Engine Discussion; my 99 sls keps shutting off out of nowwhere, no sign of stall or anything. i checked for code and ...
    Senseless is offline Cadillac Owners Member
    Jul 2006
    6
    99 seville sls
    my 99 sls keps shutting off out of nowwhere, no sign of stall or anything. i checked for code and the only code showing ic pcm p1599. Could anyone lead my in the rigt directions of fixing the problem.
    > I checked the FPR , and found nothing leaking.
    > With the ignition key ON ( ENGINE OFF), the only light come on is, { OIL, BATTERY, SERVICE ENGINE SOON}.
    What's the chances of the pcm is bad, or how should i know.
    Thanks for the help if anyone can help me.
    rbrandon's Avatar
    rbrandon is offline Cadillac Owners Member
    Automobile(s): 99 STS
    Jul 2004
    Brooklyn, NY
    35
    71
    Re: 99 seville sls
    check both crank sensors
    68
    81,916
    Re: 99 seville sls
    CPS (Crankshaft Position Sensors)
