Expensive Air Filters Worth it???
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, Expensive Air Filters Worth it??? in Cadillac Engine Discussion; I am not talking about the complete re-fits with "cold air" intakes. But the simple rectangular filters. Do "hi-flow"s like ...
    Elmer Fudd is offline Cadillac Owners Fanatic
    Automobile(s): 99 Deville Concours
    Jul 2006
    Tuscaloosa, Al.
    60
    199
    I am not talking about the complete re-fits with "cold air" intakes. But the simple rectangular filters. Do "hi-flow"s like K&N really help performance signifcantly??? I know, what is significant?? Well I would say going from 300 hp to 301.5 is not significant, but 310 would be......
    Jul 2006
    Tuscaloosa, Al.
    60
    199
    Re: Expensive Air Filters Worth it???
    Well, it may not matter. Went to the K&N site to get a part number and when I put in 99 deville, all the show is an oil filter.........
    Frost's Avatar
    Frost is offline Cadillac Owners Connoisseur
    Automobile(s): 1988 SDV; 1997 SDV D'Elegance
    Aug 2003
    Ontario Canada
    1,401
    You might call them directly - they don't always have everything in their inventory listed on their website, espcecially with our "older" cars - I got a K&N air filter that way,,,,,
  5. #4
    Jul 2006
    Tuscaloosa, Al.
    60
    199
    Yes, this morning I checked some on-line parts stores and they had them. BOth said the same K&N number, so I'm sure its right.
  6. #5
    68
    81,738
    Quote Originally Posted by Elmer Fudd
    No. Do a search. This has been discussed many times. You'll find enough reading material to keep you bussy for days.
  7. #6
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,167
    As strange as it may seem. The original AC Delco filter is the most efficient on the market. Not only does it do the best job of filtering out the dirt, it also holds the most dirt before it becomes restricted. The only thing the aftermaket filters provide is an easy path for small rocks into the engine.
  8. #7
    JohnnyO's Avatar
    JohnnyO is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado, '04 DeVille
    Nov 2003
    Pittsburgh, PA
    194
    Most air filters, even paper ones, are big enough that the paper isn't really much of a restriction. A 500 cube big-block is different. A N* is a great engine but displacement-wise it ain't all that big and therefore doesn't flow all that much air. I tried a K&N in my previous truck and didn't see a difference in either mpg or performance. I use NAPA Gold air filters these days.
  9. #8
    Jul 2006
    Tuscaloosa, Al.
    60
    199
    Yes, after reading some past posts, it makes sense to stick with ordinary filters.......
  10. Remove Advertisements
