Coolant system question
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, Coolant system question in Cadillac Engine Discussion; 2001 Northstar 4.6 when the overflow tank overflows, where does the overflow go?...
    OffThaHorseCEO is offline Cadillac Owners Connoisseur
    Automobile(s): 2013 ATS Premium 3.6, 1989 Allanté
    Jul 2005
    Fayetteville NC
    33
    4,513
    2001 Northstar 4.6
    68
    82,070
    Re: Coolant system question
    Overboard, on the road, garage floor, parking lot etc. Just follow the overflow hose and you'll see.
    Elmer Fudd is offline Cadillac Owners Fanatic
    Automobile(s): 99 Deville Concours
    Jul 2006
    Tuscaloosa, Al.
    61
    199
    If you add collant you need not fill it to the neck. At least on mine when I did that it promptly overflowed in the driveway when it warmed up. An inch down works for me.
    If it does overflow, be sure to hose the stuff off with lots of water very proimptly. That stuff attacts dogs and cats with the sweet smell and is poisionous (at least the old green stuff was).
    Jul 2005
    Fayetteville NC
    33
    4,513
    ok then i dont need to worry about a busted hose
    now onto the possibly bigger issue, what would cause a normally non leaking 2001 Deville to overflow to the point of spillage to the point of a low coolant message
    today is a 94 degree day, the car usually runs with the ac on but has never had an overheating problem, my brother was driving it and didnt experience a problem until parkin here at the office parking lot, he used the highway to get here with a average constant speed of 65 mph, no stop and go
    i hope this isnt a big issue
    68
    82,070
    Remember, when you shut down, the cooling systen ceases to operate, but the cylinders are still hot and the engine will actually heat up (after boil). As it does the coolant will over flow if too full as Elmer mentioned. That will usually only happen once as the system is sort of seeking its correct level. If it does not overheat when driving, then perhaps the cap is getting weak. Does this happen with every shut down? Are you overfilling it? Proper level on an '01 is about 1/2 full, just about where the tank goes from translucent to opaque.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Correct, on the top of the tank in small letters you'll see where it says 'full when hot' and there is a line there. If you follow the line down the side of the tank you'll see that, as Ranger said, it stops right where the tank changed from translucent to black.
    Where is your gauge sitting while you're driving? and as far as the after boil, sometimes when it's really hot out and I park the car, turn it off, and come back to it a few minutes later my gauge will be slightly above center. I've never seen it higher than that due to that affect.
    Quote Originally Posted by Ranger
    Jul 2005
    Fayetteville NC
    33
    4,513
    today was the first time ever, drove it str8 to autozone to buy some dexcool and filled it pretty high, about 1.5 inches from the top
    even with low coolant the needle sat at mid temp
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    perhaps air somehow got into the system?
    failing/stuck thermostat... the post shutdown heat up forced it open and it surged
    tman2093's Avatar
    tman2093 is offline Cadillac Owners Fanatic
    Automobile(s): 1999 White Diamond STS with Sirius, 2001 Silverado
    Jun 2006
    Chapel Hill, NC
    440
    Quote Originally Posted by Elmer Fudd
    It actually tastes good. I accidentally had a taste of it (long story) and I can see why dogs like it. It's not bad at all.
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,241
    Anti-freeze, glycol, is used to sweeten inferior wines in Europe in small amounts.
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,947
    Quote Originally Posted by dkozloski
    Reading statements like that make me glad that I have been a "Friend of Bill W." for over 9 years now.
  14. Remove Advertisements
