hard start when hot, not FPR
Results 1 to 12 of 12
Northstar Engines and System Technical Discussion Discussion, hard start when hot, not FPR in Cadillac Engine Discussion; car starts up fine in the mornings, after a nights rest. and after driving it and parking it for about ...
    fpmesiIII's Avatar
    fpmesiIII is offline Cadillac Owners Fanatic
    Automobile(s): 1996 Cadillac Seville STS (167k)
    May 2005
    Western NY
    473
    Questionhard start when hot, not FPR
    car starts up fine in the mornings, after a nights rest. and after driving it and parking it for about less than 10 minutes, it starts up fine. but after that it is hard to start. i checked the FPR, and it holds a vacuum. I just replaced spark plugs and wires, with AC-Delco. any ideas what needs to be fixed in order for my hard starting to go away for good?
    68
    81,917
    Re: hard start when hot, not FPR
    Does the fuel pressure hold after shut down? Perhaps a leaking injector?
    fanofsims2 is offline Cadillac Owners Member
    Automobile(s): 1994 Eldorado 4.6
    Aug 2004
    17
    An ignition module can also heat up and make it hard to start, requiring a cool down period.
    weister42 is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville Sedan
    Feb 2005
    897
    I have the same problem...not the FPR and I got the plugs & wires changed along with fuel filter and a few relays. One mechanic couldn't tell me jack and the other one says all eight of my injectors are seeping when he lifted the fuel rails. It happened right after I installed a stereo but I can't see how it can affect the engine
    Hey fpmesiIII can you give more details on the service history and any recent upgrades to your car? When you park for 10~15 minutes and try to start does it start almost too quick? The chances of ALL of my injectors seeping at the same time sounds suspecious to me.
    Basically your engine is flooded with gas. You can start your car better by pressing on the gas pedal to open up the throttle body. If this trick works then me and you share the exact problem.
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    no upgrades all stock, except for magnaflow mufflers. my mechanic said that i have leaky fuel injectors. and to replace them at $100 dollars each it was not worth the $800. since it has 148k and is 10 yrs old.
    it does sound kinda bad though when you try to start it and it just doesnt fire prompty. i will try to hold down the gas peddle and see if that changes anything. funny thing is that it starts up fine after a long sit and a quick sit. but anywhere after too short and too long it acts up. im guessing a long sit would be like 8+ hours and a short sit would be like under 10 minutes.
    I just hope there is something i can do to fix the problem without paying 800 bucks for those damn fuel injectors.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,215
    Off to the local auto salvage yard.
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    update: holding gas peddle down does not help.
    Feb 2005
    897
    Holding down the gas pedal only "helps" to get the gas outta the engine, on a really hot day I have to press the pedal down fully for a few seconds for my car to start, otherwise I'll have to sit there and crank like I have a broke ass caddy . I've been driving with this problem for awhile now and I think it's getting worse...yep off to salvage yards...
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    If you suspect the injectors and you can afford some downtime, the folks at RC Engineering can bench test, balance and blueprint your injectors.
    I had mine done on a TurboCoupe and they came back looking like new.
    fpmesiIII's Avatar
    May 2005
    Western NY
    473
    im pretty sure its the injectors. the problem is all of the salvage yards around here have no newer caddys. everytime i call they have nothing. if i did manage to find one. where on the engine would i have to go in order to retrieve the fuel injectors?
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,215
    Contact Leroy and Bubba down at the pool hall. They'll meet you out on a country road with a "parts car" and you can have anything you want.
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,357
    Leroy & Bubba are in Fairbanks looking to jack a CTS for parts.
  15. Remove Advertisements
