thermostat for north star
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, thermostat for north star in Cadillac Engine Discussion; Getting some parts for my newly rebuilt engine, the local parts store the only thermostat that is available for the ...
    denscor is offline Cadillac Owners Fanatic
    Nov 2005
    Point Pleasant,West Virginia
    50
    174
    Getting some parts for my newly rebuilt engine, the local parts store the only thermostat that is available for the north star is a 180 degrees this correct?seems little cool to me.Also would you use AC water pump or cardone brand. I have heard that AC plug wires are the only way to go.Thanks
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: thermostat for north star
    The service manual says the operating range of the thermostat is from 188 degrees to 206, so I would say it's a 190. Just play it safe and put all Delco parts on the engine.
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,361
    The proper thermostat is in fact a 180 deg. If you go to the AC Delco web page and look up the thermostat for a N* it's a 131-128 and it says 180. Not only that but Stant mfg's the thermostat for AC Delco. So you can use a Stant 14228 180 thermostat. How do I know this? I bought both parts to compare. They are identical.
    From AC Delco web site: 131-128 is w/o gasket or 12TH11D with gasket.
    1995 CADILLAC ELDORADO V8 4.6L 281cid GAS FI N Engine VIN = Y
    Qty Req Qty ACDelco Part# Description
    COOLING SYSTEM / THERMOSTAT
    01 131-128 THERMOSTAT,ENG COOL
    LESS GASKET
    01 12TH11D THERMOSTAT,ENG COOL(W/GSKT) ALL MAKES-STD LINE
    RECOMMENDED TEMP 180 DEGREE INCLUDES SEAL
