95 Intake Manifold Interchange?
Results 1 to 7 of 7
Northstar Engines and System Technical Discussion Discussion, 95 Intake Manifold Interchange? in Cadillac Engine Discussion; Are there any other year intake manifolds that'll work on a 95 motor?...
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Feb 2004
    FL
    2,250
    Re: 95 Intake Manifold Interchange?
    yes - 96-99. The vacuum ports are set up a little differently. You will need the FPR vacuum line from the same year.
    clarkz71's Avatar
    clarkz71 is offline Cadillac Owners Connoisseur
    Automobile(s): 2000 Eldorado ESC
    Mar 2006
    Fort Lauderdale, Florida
    53
    1,357
    Does the 96-99 manifold have a MAP sensor port to mount it to?
    Feb 2004
    FL
    2,250
    uhh... no?
    It's exactly like the 95, they just moved the FPR vacuum nipple from the top to the side or vise versa. I forget.
    clarkz71's Avatar
    Mar 2006
    53
    1,357
    I'm not talking about the FPR (Fuel Pressure Regulator), I said MAP sensor, as in Manifold Absolute Pressure sensor. The 96-99, as I'm sure you know use's a MAF. The 95's MAP sensor attach's directly to the manifold next to the throttle body flange. It doesn't have a vac hose going to it, it mounts to a port on the manifold.
    Feb 2004
    FL
    2,250
    They're the same except the FPR vacuum nipple location
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Thanks eldorado1.
    The 125 jets go in tomorrow.
  10. Remove Advertisements
