oil pan gasket change, is this quote correct!?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Northstar Engines and System Technical Discussion Discussion, oil pan gasket change, is this quote correct!? in Cadillac Engine Discussion; peb boys just quoted me 800.00 then a 2nd pep boys quoted me 922.00 for the change!? that sound right? ...
    ese
    ese is offline Cadillac Owners Member
    Mar 2005
    22
    peb boys just quoted me 800.00 then a 2nd pep boys quoted me 922.00 for the change!? that sound right? seems extremely expensive for an oil pan gasket.
    68
    81,914
    Re: oil pan gasket change, is this quote correct!?
    The engine has to be dropped to R & R the oil pan gasket.
    ese
    Mar 2005
    22
    HOLY ... damn.. well that was totally unexpected.. hahahaha
    68
    81,914
    yeah, makes a leaky oil pan a lot easier to live with, eh?
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Yeah I understand that quite a job on these cars.
    ese
    Mar 2005
    22
    lol yes very ranger.. i was shocked i thought the first guy misquoted me or something but wow...any thoughts on how to maybe remedy the problem without the 900 dollar repair?
    68
    81,914
    Yeah, if it is actually the pan and not the halfcase seal, try this. Pull the bolts one at a time (there are a few you cannot get to). Spray the threads, both male and female with Brakleen (brake cleaner), then blow out the hole with compressed air. Apply some Permatex thread sealer to the bolt threads and torque to specs. Then move on to the next til you do all you can get at. This proceedure has been reported to drastically slow if not stop a pan leak.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Can I ask what the 'halfcase' is?
    Feb 2004
    FL
    2,250
    The engine block is made of 2 halves. The top half, with the cylinders, and the bottom half. Sandwiched between the two is the crankshaft. The bottom half is really the crank bearings, and "main caps" and all. There's a seal between the two that's supposed to keep oil in that fails.
    ese
    Mar 2005
    22
    i was wondering if i can use the permatex sealent around the pan not just on the bolts?
    68
    81,914
    I'd first get under it and clean it good with a can of Brakleen. Then see exactly where it is leaking from, the pan seam, halfcase or pan bolt threads. Then you'll have a better idea of how to proceed and if it is even worth the effort.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Really? so the block is actually two pieces? I had no idea. So there's no bearing caps it's the two pieces of the bottom end?
    Quote Originally Posted by eldorado1
    68
    81,914
    Now you've got it. The bottom end is a one piece multiple main bearing cap.
  16. #14
    Feb 2004
    FL
    2,250
    Quote Originally Posted by codewize
    exactly why they're good to 8500+ rpm and 600+hp stock.
  17. #15
    ese
    Mar 2005
    22
    hard as hell to see, most of the oil is from the front of the pan, i really do think its the gasket tho, i bet its never been changed.. and it looks like theres some sealent on it already.. but its terribly applied.. siiiiigh time for a six pack and a day under the car..
  18. Remove Advertisements
