'95 Concours leaking oil between engine and trans
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, '95 Concours leaking oil between engine and trans in Cadillac Engine Discussion; 1995 Concours, 74,xxx miles Began leaking oil on the exhaust pipe, I looked and it seems to be the rear ...
    ED's85GT is offline Cadillac Owners Member
    Aug 2004
    Statesville, NC
    55
    43
    the rear main seal.
    How hard is it to replace?
    Thanks.
    Ed
    Aug 2004
    Statesville, NC
    55
    43
    Re: '95 Concours leaking oil between engine and trans
    It's leaking engine oil (just to clarify)
    Ed
    69
    82,266
    I'm guessin you'll have to drop the drivetrain and then seperate the engine & trans. Sounds like a lot of work to me.
