Northstar changes year to year
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, Northstar changes year to year in Cadillac Engine Discussion; I am just curious if anyone knows the changes with the northstar, inparticular the 2005 with the 20 extra hp ...
    Benjamin Simon's Avatar
    Benjamin Simon is offline Cadillac Owners Enthusiast
    Automobile(s): 05 STS V8 1SG with ACC, 99 STS (Sold), 06 CL500 (Wifes)
    Jun 2005
    Middle GA
    34
    960
    SmileNorthstar changes year to year
    I am just curious if anyone knows the changes with the northstar, inparticular the 2005 with the 20 extra hp in the STS. I drive a 99 and I know they changed it some in 2000. Would someone care to give me a history on the changes after my 99 STS? I had the head gaskets go out on mine, did they finally fix that problem?
    What did they do to get the extra 20 hp?
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: Northstar changes year to year
    In 2000 the compression was reduced to 10:1, and roller cam followers were added. There's some other small changes as well. The 320 HP STS has Variable Valve Timing, so that's the reason for the extra 20 HP over your '99. But the 2005-up STS is a RWD engine, so there's a bit different with that one.
    68
    81,928
    They also made change to the head bolts. Changed the thread pitch I believe.
    GreenMachine's Avatar
    GreenMachine is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Deville
    Jun 2005
    Amherst (Buffalo), New York
    29
    484
    ^also changing from the FWD version offers better breathing room for the intake and the exhaust (I believe its a true dual pipe setup rather than Y split). The engine also has a 10.5:2 compression ratio in the RWD platform. Intresting enough in the change to the RWD drive engine cadillac once again suggests using 91 octane and up for full performance and fuel economy. Basically try it on premium, then drop to 87 or 89 and see if you can notice a performance drop, if you don't, you OK to use it and still will be getting full performance.
    "STS Manual" states:
    "Gasoline Octane
    If your vehicle has the 3.6L V6 engine (VIN Code 7),
    use regular unleaded gasoline with a posted octane
    rating of 87 or higher. For best performance or trailer
    towing, you may choose to use middle grade 89 octane
    unleaded gasoline. If the octane rating is less than
    87, you may notice an audible knocking noise when you
    drive, commonly referred to as spark knock. If this
    occurs, use a gasoline rated at 87 octane or higher as
    soon as possible. If you are using gasoline rated at
    87 octane or higher and you hear heavy knocking, your
    engine needs service.
    If your vehicle has the 4.6L V8 engine (VIN Code A),
    use premium unleaded gasoline with a posted octane
    rating of 91 or higher. You may also use regular
    unleaded gasoline rated at 87 octane or higher, but
    your vehicle’s acceleration may be slightly reduced, and
    you may notice a slight audible knocking noise,
    commonly referred to as spark knock. If the octane is
    less than 87, you may notice a heavy knocking
    noise when you drive. If this occurs, use a gasoline
    rated at 87 octane or higher as soon as possible.
    Otherwise, you might damage your engine. If you are
    using gasoline rated at 87 octane or higher and you hear
    heavy knocking, your engine needs service."
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,224
    If you goto Caddyinfo.com, Bruce has all the differences from year to year listed.
  8. Remove Advertisements
