Results 1 to 8 of 8
Thread: Alternator Removal??
    chuck1985 is offline Cadillac Owners Member
    Automobile(s): 98 STS
    Apr 2006
    7
    I have a 98 STS and the service manual is saying that I have to remove the radiator AND the AC Condensor to get the alternator out?!
    Is there an easier way? I could probably stomach removing the rad, but I don't want to go through the pain of disconnecting AC lines and recharging the system just to get the alternator out.
    parts68 is offline Cadillac Owners Fanatic
    Automobile(s): 02 Escalade,96 Aurora,with Shelby engine
    Jan 2006
    345
    Re: Alternator Removal??
    Not sure on this body but the Rora says same in FSM and I get them out
    by just removing the upper radiator hose. Slide it up to the top on the other end of radiator and out by the water pump.
    Use a piece of carboard to protect the radiator from gouging.
    Mountie's Avatar
    Mountie is offline Cadillac Owners Enthusiast
    Automobile(s): '93 STS (sold), now looking for a CTS Wagon soon!!
    Jul 2005
    Bradenton, Fl
    62
    502
    Quote Originally Posted by chuck1985
    If your STS is anything like my '93 STS, there is a 4-bolt access plate directly below the Alternator. By removing the R/F wheel, and removing the plastic fenderwells, ( sounds worse than it is ) your ability to loosen the A/C, to get at the Alternator bolts may be all you need, but I know ( as in my car) you can drop the 'nator down. When the job is finished, make SURE the wire is not near the fan!! Use tie-wraps if needed.
    My suggestion> Go to your friendly Cadillac Dealer Service ...go straight to the service mechanics! They will tell you.
    By the way, I had my Alternator Hand-Re-Done by the best shop, ....it shouldn't ever have to come out!
  5. #4
    Apr 2006
    7
    I think the 98 and newer models are a little more difficult than the older cars as they don't have that "access panel" in which you can remove to drop the alternator out.
  6. #5
    Mountie's Avatar
    Jul 2005
    Bradenton, Fl
    62
    502
    Bummer
  7. #6
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    I don't recall ever having to remove a radiator to get an alternator out.
    Hang on let me look it up....
    Hmmm... service manual does call for radiator and condensor removal.
    That probably has one of those crazy alternators with coolant running through it doesn't it?
    I am guessing it might be right, I don't recall ever having to replace one of those so I am not sure.
  8. #7
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,959
    Yes...the '98 STS has a water cooled alternator, but I don't think that has anything to do with the reason the book says to remove the radiator and condenser.
  9. #8
    Sep 2003
    1,471
    Not much room under there on the '98+. Wait'll you ever have to remove the front valve cover.
  • You may not post replies
