Engine Stall
Results 1 to 6 of 6
Northstar Engines and System Technical Discussion Discussion, Engine Stall in Cadillac Engine Discussion; OK Cadillac wizards, put your thinking caps on. No codes showing. Deville DTS 32v Northstar. 34,340 miles as of tonight. ...
    SHERIFF's Avatar
    SHERIFF is offline Cadillac Owners Fanatic
    Automobile(s): DTS
    Sep 2004
    205
    Engine Stall
    No codes showing. Deville DTS 32v Northstar. 34,340 miles as of tonight. Every time I start the car for the first time in the day.... it runs fine for 2 minutes and then cuts off. It will always restart on the third attempt and runs fine thereafter.
    When this problem first started about two weeks ago, I did get a check engine light. It went off on the third thermal cycle and never came back on.
    WTF is going on? Any suggestions? It's just plain annoying now.
    68
    81,926
    Re: Engine Stall
    If you got a check engine light, there should be a DTC stored. If it is a 2000 - 2003, I would lean towards the CPS (Crankshaft Position Sensors).
    SHERIFF's Avatar
    Automobile(s): DTS
    Sep 2004
    205
    Re: Engine Stall
    They have already been replaced under warranty once. Could be them again I suppose.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: Engine Stall
    The crank sensors were replaced twice on my STS due to failures!
    SHERIFF's Avatar
    Automobile(s): DTS
    Sep 2004
    205
    Re: Engine Stall
    I'm beginning to think I got a bad tank of gas. Having filled up the other night again (8 gallons), it is improving.
    Now that I think about it, I also had a similar problem with a Crown Victoria with gas from the same station. I promised myself to never buy gas there again.
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Re: Engine Stall
    Hmmm...maybe you have some water in there! A local station here filled a car up with about 5 gallons of water from thier tanks! It did quite a bit of damage to the car.
  9. Remove Advertisements
