93 sts rough idle and fluttering under acceleration
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, 93 sts rough idle and fluttering under acceleration in Cadillac Engine Discussion; hi guys today after driving my 93 sts for about 1.5-2 hrs and after just coming off the freeway i ...
    silver duke is offline Cadillac Owners Member
    Automobile(s): 93 cadillac sts seville
    Oct 2005
    vancouver bc
    44
    hi guys today after driving my 93 sts for about 1.5-2 hrs and after just coming off the freeway i switched my a/ c off. my sts than began to idle rough and to flutter under acceleration. the car has 120,000 miles. i than pulled over and allowed the vehicle to sit. after about 10-15 minutes i re started it ran normal i drove home about 40 minutes than once again it began to idle rough and flutter/miss under acceleration. the temperature remained normal although the entire time. i was worried about the head gasket but the temperature has remained normal so far. i will try the regular tune up first but any ideas would be greatly appreciated. i love my sts and need it to run awesome like it did before.before today it ran great, i 2nd gear de- carb it every so often. i already changed the air filter,pcv,and cleaned the throttle body a few months ago not the plugs or leads yet. thanks guys you all help keep my sts on the road
    68
    81,926
    Re: 93 sts rough idle and fluttering under acceleration
    First pull the DTC's. Then if plugs & wires are original, they are due.
    Mountie's Avatar
    Mountie is offline Cadillac Owners Enthusiast
    Automobile(s): '93 STS (sold), now looking for a CTS Wagon soon!!
    Jul 2005
    Bradenton, Fl
    62
    502
    Also the EGR valve?
    I was told, when you need to clean the injectors, to use injector cleaner..... 3 bottles, one every 1/3 tank before fill up. A hundred gallons of treated fuel usually does a good job. When it's time to clean them.
    CadiJeff's Avatar
    CadiJeff is offline Cadillac Owners Connoisseur
    Automobile(s): 1981 CoupeDeville, 2 1990 Eldorados, 1994ETC ,1992STS
    Feb 2004
    Nerk,Ohio
    36
    1,072
    add coil packs to the list
  7. Remove Advertisements
