Low Oil Pressure
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, Low Oil Pressure in Cadillac Engine Discussion; When my N* returns to idle for a while (such as at a stoplight) when the temp is up around ...
    Aurora By Olds is offline Cadillac Owners Fanatic
    Automobile(s): 2000 DTS
    Oct 2003
    Fort Myers, FL
    33
    197
    Low Oil Pressure
    When my N* returns to idle for a while (such as at a stoplight) when the temp is up around 220 - 230 the oil pressure often drops to nothing. I know there is stil circulation, but I would have better piece of mind with a few psi.
    What is a good grade of oil to run that would increase pressure just a bit without being too thick to starve the engine.
    I used to run 10w-30 in it, but recently put in 5w-30 (cause I had a free case) which exacerbated this problem quite a bit. I live in a cool climat right now, and will probably be moving to FL soon, so I will need something that can withstand higher heat. Any suggestions?
    68
    81,891
    Re: Low Oil Pressure
    10W40 or Rotella 15W40
    Oct 2003
    Fort Myers, FL
    33
    197
    Those were the two I kind of had in mind, just wanted a second opinion. Thanks.
