When buying a Northstar powered car....
Results 1 to 12 of 12
Northstar Engines and System Technical Discussion Discussion, When buying a Northstar powered car.... in Cadillac Engine Discussion; When one is buying a Northstar powered car, what are the things you definetly have to look at? What are ...
    I~LUV~Caddys8792's Avatar
    I~LUV~Caddys8792 is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 Town Car Cartier & 2014 Accord LX MTX
    Dec 2004
    Roseville, MN.
    29
    34,087
    When one is buying a Northstar powered car, what are the things you definetly have to look at? What are the things that should tell you not to buy this car?
    Feb 2004
    FL
    2,250
    Re: When buying a Northstar powered car....
    on your test drive, pull over and pull the codes.
    overheating would be a "bad sign"
    Check the general maintenance stuff for good measure.
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Take a loooong test drive. Stop several times. Go uphill or on the highway if possible. Put a couple of dollars gas in it.
    You are checking for overheating. Especially uphill or at high speeds. Watch for any spitting out the overflow tank. THe rest of the time watch for any obvious problems. You should take enough time...at least a half hour...to get used to the car and notice any problems.
    A ride around the block doesn't show up anything but the most glaring problems.
    AlBundy's Avatar
    AlBundy is offline Cadillac Owners Master
    Automobile(s): 1996 Eldorado Sport Coupe, 2009 Black Navigator
    Jul 2005
    Chicago
    5,016
    Quote Originally Posted by I~LUV~Caddys8792
    Your finally going to bit the bullet and purchase one or are you just doing your homework. Either way good for you.
    itsabughunt is offline Cadillac Owners Member
    Jan 2006
    66
    Isn't the salesman going to think you're nuts if you want to test drive it for half an hour? Not that it matters I guess, but I'm just curious if its normal to test drive for so long. I wouldnt really know since so far I've only bought my cars from family members.
    Dec 2004
    Roseville, MN.
    29
    34,087
    Quote Originally Posted by ALBUNDY
    Just doing my Homework. I really like ETC's and DeVille Concours
    It's a bighunt, I took that '84 SDV out for like 35 minutes. Owner didn't mind at all.
    Sep 2003
    Arizona
    3,531
    Quote Originally Posted by itsabughunt
    Who cares what the salesman thinks! You are going to live with the car, not him. The dealers here usually give you an hour to test drive it.
    Most people are foolish and don't take the time to really test drive the car.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Apparently in addition to
    oil leaks (mostly pre 2000) and temp problems
    we need to look at the front motor mount. Very commonly broken even with extremely low mileage. Not a cheap repair. Take the time to check this out.
    STS 310's Avatar
    STS 310 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 STS
    Dec 2003
    LOS ANGELES CA
    1,489
    Quote Originally Posted by codewize
    Motor mount is an easy fix, and would be probably fixed by a "tech" at the lot if pointed out. Long test drive and use you nose after the the drive and actually during. Pull over and lift the hood with the engine running. Smell the whole compartment. Onle reason you should smell coolant is if it was just changed, and then be leory. Collant smell is not some thing you want to smell, and if someone is trying to get past a hg or pump, they will say "Oh some coolant just spilled on the heads " or something like that.
    Be prudent, and suspicious.
    Shame we have to be so militant, but......
    Dec 2004
    Roseville, MN.
    29
    34,087
    Quote Originally Posted by zonie77
    Whoa! An hour?! I always thought he'd think I was stealing it if I took it out for more than like 15 minutes.
    I agree, but sometimes it's hard to take it out for a while if the salesmen is pressuring you or if the car has a low tank of fuel like that '77 Town Car I drove last week. I wanted that car for longer but the damn low fuel light was on at 1/4 tank!
    Sep 2003
    Arizona
    3,531
    I~luv~caddys8792,
    Your the one spending the money. Don't let him have control of the dealings.
    I would have told him you were interested in buying the Lincoln but if you couldn't give it an adequate test drive,too bad, you were looking elsewhere. I bet he would have scraped up $5 for gas. If it was a private party I would have put a couple bucks in myself, but a dealer can keep a little gas in it. ( Really a private seller should too but they can get upset and putting a few bucks in can help when you're negotiating.)
    I don't buy from dealers (once in my life) but read a book about buying from dealers some years ago. I don't remember the name but it was full of info on how the dealer negotiates. Everyone should read it before going to the dealer.
    When I buy I don't always do as I say, but I do give every car I buy a thorough going over. I know I drive further than the average person, not a half hour necessarily.
    Dec 2004
    Roseville, MN.
    29
    34,087
    I would have told him you were interested in buying the Lincoln but if you couldn't give it an adequate test drive,too bad, you were looking elsewhere. I bet he would have scraped up $5 for gas. .
    I told him prior that I wasn't gonna buy that car at this point, but the '70s Lincolns are one of my dream cars and that I've always wanted to drive one.
    It was by his good grace that I got to drive it. Most dealers would have told me to screw off.
    I was thinking about throwing $5 in the tank, but I realized in a tank that's 28 gallons, $5 would barely move the needle on the guage, and it would still probably leave the "low fuel light" on. And those two gallons of gas would be gone by the time I put about 22 miles on the car. Plus, I was kinda intimidated by the size.
  15. Remove Advertisements
