Overheating 95 Seville Sls
Results 1 to 12 of 12
Northstar Engines and System Technical Discussion Discussion, Overheating 95 Seville Sls in Cadillac Engine Discussion; New Radiator, Thermostat, Coolant At 50/50 Mix, Fans Are Operating Properly But My Vehicle Overheats. When Info Button Is Pushed ...
    BIGMAN-7 is offline Cadillac Owners Member
    Jun 2006
    10
    QuestionOverheating 95 Seville Sls
    New Radiator, Thermostat, Coolant At 50/50 Mix, Fans Are Operating Properly But My Vehicle Overheats. When Info Button Is Pushed No Info Displayed. Obd Works Fine But Information Won't Display When Button Is Pushed. The Car Is Overheating And The Displays Says ...a/c Compressor Off... Idle Engine.... Engine Overheat...... It Has 135k
    68
    81,926
    Re: Overheating 95 Seville Sls
    Check the water pump belt tensioner and make sure the purge line is clear and flows coolant. If all is ok, do a cylinder pressure test.
    Jun 2006
    10
    WATER PUMP BELT TENSIONER OK, PURGE LINE CLEAR, NO LEAKAGE IN COMPRESSION TEST.....??????????
    68
    81,926
    Hmm, not using any coolant? No bubbles in the surge tank when started cold with the cap off? Perhaps a faulty tempurature sensor.
    Jun 2006
    10
    Thanks for the input......... drained and replaced coolant with dex cool....... problem solved!!!!
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Does it lose coolant?
    Ranger suggested a cylinder pressure test, not a compression test.
    Have a combustion byproduct test done. Radiator shops usually do them inexpensively.
    There's a large chance the headgaskets are leaking.
    Jun 2006
    10
    Mistake on test noted but so far the vehicle hasn't run hot since replacing coolant with dex cool...... it would normall run hot after 30 mins of normal driving...... no problems with my daughter driving it all day. I will have the cylinder test done for reassurance..... thanks.
    Sep 2003
    Arizona
    3,531
    You should have the combustion byproduct test done after the coolant is in there awhile. Like I said, radiator shops do them much cheaper than mechanics.
    Jun 2006
    10
    If headgaskets are leaking....... what then?
    Jun 2006
    10
    another question..... what can be the cause of no information displayed when the info button is pushed? "change engine oil" can not be reset and nothing can be monitored...( coolant temp.... voltage) car flashes "system" and "change engine oil" while driving...... computer maybe? if so, where is it's location if it nedds to be replaced.... my daughter loves the car.....
    68
    81,926
    Fix it,
    sell it "as is",
    junk it
    Only choices I can think of.
    Jonny5 is offline Cadillac Owners Fanatic
    Automobile(s): 95 gold-n-cream SLS
    Jul 2005
    St Louis
    32
    385
    to fix, a faulty head gasket will cost about 2 grand or more. Then a new computer is another grand or so....... Get a new car
  15. Remove Advertisements
