Nothstar fairytails
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Northstar Engines and System Technical Discussion Discussion, Nothstar fairytails in Cadillac Engine Discussion; I'm new here, so maybe there is allready a thread about this, but I a long time ago I heard ...
    dutch STS's Avatar
    dutch STS is offline Cadillac Owners Member
    Jun 2006
    The Netherlands
    34
    18
    Nothstar fairytails
    but I a long time ago I heard a story about the design and performance of the Northstar engines.
    Somebody told me Northstar engines were build to last several miles without oil in them and some other things like that. (note, the person that told me these things is a real big Cadillac fan, so he thinks there is no better engine than the Northstar, and I share that thought), but are there things like this know by you?
    Was the Northstar engine designed to last under the wurst conditions?
    JohnnyO's Avatar
    JohnnyO is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado, '04 DeVille
    Nov 2003
    Pittsburgh, PA
    194
    CoolRe: Nothstar fairytails
    Not without oil, but there is a "limp home" mode that the engine will run on 4 cylinders at a time if there is no coolant, like if you had a bad leak or blown hose or whatever.
    dutch STS's Avatar
    Jun 2006
    The Netherlands
    34
    18
    ok, tnx. Does are the things I am trying to find out.
    But it also switches of cilinders when driving at one speed, doesn't?
    Feb 2004
    FL
    2,250
    No, it doesn't turn off cylinders. You're confusing the northstar with some of the latest engines with "displacement on demand"
    68
    81,926
    Depends on what you are talking about here. When in the limp home mode (overheated engine), the Northstar will alternately shut down left & right bank injectors and just pump air through the cylinders to aid in cooling and thus allowing the 50 miles with no coolant. It is not displacement on demand where it will disable valves and run on 6 or 4 cylinders as needed.
    The Northstar was designed and tested to be a high performane engine. It was tested at WOT for hours on end and it needs to be run hard. Occassional WOT burst are recommended and if you have never driven one at WOT, you are in for a treat.
    No engine will run without lubrication.
    dutch STS's Avatar
    Jun 2006
    The Netherlands
    34
    18
    ok, so the story that it will run 90 miles without oil isn't true, but it will run for a longer period at the max rpm (don't exactly know what WOT is).
    Haha, btw; I was telling a friend of mine your story JohnnieO about the coolant . He has a '92 STS and a '90 Allante both without Northstar. He's trying to sell me his STS, but I want a Northstar model. He says his engine is just as good.
    After him and me spoke on the phone, he went for a short drive and the temp. ran up really high causing the engine coolant to boil. He stopped and saw a cut hose. He drove home carefully refilling water all the time.
    haha, I could't stop laughing, because I just told him the story about the Northstar engine and how it reacts to a cooland leak. And he said that had now extra value. It was like the Cadillac Gods heard him say that.
    68
    81,926
    WOT = Wide Open Throttle
    Feb 2004
    FL
    2,250
    Quote Originally Posted by dutch STS
    JohnnyO's Avatar
    Nov 2003
    Pittsburgh, PA
    194
    That can happen.
    Also, Cadillac came out with (I think) the first variable displacement motor in (I think) 1980, known as the V-8-6-4. It would run on either 8, 6, or 4 cylinders depending on the demand for power and to save on gas. Basically it ran like crap and jerked a lot and within a few years most people clipped the wire so it just ran on 8 cylinders all the time. I worked at a Cadillac dealer in 1983-84 and we did this. 1981 was the last year they made that engine.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    He probably has the 4.9 which isn't even close to a Northstar. I think the 4.5 in my STS is a closer resemblance. I often wonder if it was a test bed for the Northstar development.
    Also the claim to fame on the 'no coolant' thing was 50 miles at 50 miles per hour.
    No oil would cause immediate failure in any engine. However due to the high oil volume and small displacement of the Northstar, the oil change duration is extended beyond other engines. 12,000 miles or 1 year.
    dutch STS's Avatar
    Jun 2006
    The Netherlands
    34
    18
    Ok, thanks. This is the information I was looking for. It's nice to know things like these about a brand/model you like. Espaccially if everybody says your crazy driving in a car like these. Gasoline prices have never been as high as they are now (about $1,75 per littre) and I pay at least double the amount of road-tax as people with European or Japanese cars, because it goes by the weight of your car here.
    So you have to come with good arguments to drive a car like this, other than "I'm crazy 'bout Cadillac". Haha.
    68
    81,926
    Quote Originally Posted by codewize
    That has nothing to do with the extended oil change interval.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Ohhh ? I didn't look this up but from a logistical standpoint it certainly makes sense to me. So then why is there such a long change interval.
    Quote Originally Posted by Ranger
  16. #14
    68
    81,926
    If you are refering the the increase from the 7,500 mile cap pre 2000 to the 12,500 cap after 2000, it was due to the addition of the roller finger followers in 2000. On the pre 2000 engines, under ideal conditions the OLM did not cap at 7,500 because the oil was dirty, but because it was worn out (for lack of a better term). The flat tappet lifters had a shearing effect on the oil which wore it out sooner. The Guru could explain it better than I but that is it in a nut shell.
  17. #15
    STS 310's Avatar
    STS 310 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 STS
    Dec 2003
    LOS ANGELES CA
    1,489
    Me and other members would rather not test the limits of the Northstar. It might be able to with stand those extremes, but why test if not necessary? Nice to know if I am in Death Valley and my wife is pregnanat and having a baby within the next hour, but really. When my STS over heated I shut it down and towed that girl. Why becasue I could for one, and another, I just could.
    Shes a beast and a hearty one to boot, but test her to the limit, and she will tax your ass something serious if it s is critical.
    Actually Ive tested the Northstar to great extremes with NO coolant for short durations. I wont do it again.
    No castrophic problems, but I wont ever go there again....
  18. Remove Advertisements
