Anyone know what "P1320 - IC 4X Reference Circuit Intermittent" means?
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, Anyone know what "P1320 - IC 4X Reference Circuit Intermittent" means? in Cadillac Engine Discussion; Car is misfiring. Had same problem a year ago. Did Delco plugs and Bosch wires. Problem was solved. About three ...
    sprj is offline Cadillac Owners Member
    Automobile(s): 1997 Seville SLS
    Mar 2005
    Detroit, MI
    41
    50
    Car is misfiring. Had same problem a year ago. Did Delco plugs and Bosch wires. Problem was solved. About three or four weeks ago, car started misfiring again. I placed a post and someone said "GET THE DELCO WIRES!" I replaced the Bosch wires because I got them warranteed for free. Problem was solved, for about three weeks. Now just a couple days ago, car started misfiring again. "P1320 - IC 4X Reference Circuit Intermittent " was the only significant code... there was a body code for 'front vertical sensor' too, but I think it is unrelated.
    I am trying to get the coilpacks tested. I don't know if I should spend the money on Delco wires, replace the coilpacks, the dock that they sit on... or maybe something else I am overlooking, ignition control module, etc? I am hoping I can pinpoint what is wrong with this thing instead of 'stabbing in the dark' and guessing what is wrong at a $100 - $250 per guess. I just don't have the money to do that.
    Sep 2003
    Metro ATL
    4,854
    Re: Anyone know what "P1320 - IC 4X Reference Circuit Intermittent" means?
    Remove and install each of the low voltage connectors on the ignition control module several times; this will wipe the contacts clean.
    Mar 2005
    Detroit, MI
    41
    50
    Quote Originally Posted by JimD
    Are these the two plugs on either side of the coilpack assembly?
    Sep 2003
    Metro ATL
    4,854
    Yes.
  7. Remove Advertisements
