NorthStar Head Bolts
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, NorthStar Head Bolts in Cadillac Engine Discussion; NorthStar head bolt questions Do the head bolts need to be torqued down again after they have been installed and ...
    Lonezuk is offline Cadillac Owners Member
    Apr 2006
    USA
    74
    Do the head bolts need to be torqued down again after they have been installed and the engine used ?
    How about if time-serts were used ?
    Looking down into the bolt holes, how can one tell if an engine has time-serts ?
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Re: NorthStar Head Bolts
    The head bolts don't need to be retorqued after running. There is a sealant on them and there is no easy way to retorque them. I think the retorqueing has been eliminated with newer head gaskets.
    If you look at the thread holes you will see a different colored (steel) ring in the aluminum. That would be the timesert.
    N-star is offline BAD EMAIL ADDRESS
    Jul 2005
    39
    Bump
