Flushing radiator 98 deville
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, Flushing radiator 98 deville in Cadillac Engine Discussion; Can anyone tell me how to drain the radiator on a 98 Deville?? Thanks for your help!!!!...
    rgtplus3 is offline Cadillac Owners Member
    Apr 2006
    17
    68
    81,926
    Re: Flushing radiator 98 deville
    Open the drain plug under the left side of the radiator. There should be a small hole to get at it but it is difficult to reach. Make a tool like a 3/4" dowel rod with a slot cut in the end to help turn it, or just pull the lower hose. You'll have to remove the hose anyway to insert the sealant tabs (cooling system suppliment).
