Rebuilt Northstar, No Codes, Poor MPG
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, Rebuilt Northstar, No Codes, Poor MPG in Cadillac Engine Discussion; Background - had major oil leak straight onto exhaust and gasket leaks on both heads. Rather than just fix these ...
    chevyorange's Avatar
    chevyorange is offline Cadillac Owners Fanatic
    Oct 2004
    Federal Way
    44
    351
    QuestionRebuilt Northstar, No Codes, Poor MPG
    Background - had major oil leak straight onto exhaust and gasket leaks on both heads. Rather than just fix these things had a rebult put in.
    Has TONS of power. I love the thing but I'm averaging 14.5MPG whereas before I was closer to 18 with a lead foot. I know on trips that were pure freeway I could average 23 to 26 with A/C on and cruise.
    This could be a matter of just me loving the power but I don't think I'm driving much differently.
    No codes, new engine internals, no codes. Slight, non consistant idle dropping a few hundered RPM every minute give or take but not like clockwork, if you catch my drift, completely staccato and sometimes idles without it. But mostly when warmed up, ever 30 to 60 seconds the idle drops from about 750 to 500, catches, and back to normal.
    Throttle response is good, tapping the throttle makes her wanna take off a little harder than I remember.... but there is no hesitation when under any throttle condition hot or cold.
    Could this just be a few MPG with new internals breaking in. We're literally talking less than 400 miles.
    Normally I'd not ask about MPG but I want to make sure my "new" engine is working correctly. I'm sure it isn't internals - things are too smooth.. too SWEET watching that tach sweep up smoothly and quickly.
    Adam
    auroradude's Avatar
    auroradude is offline Cadillac Owners Fanatic
    Automobile(s): 95 Aurora, 08 Z06
    Jun 2005
    WC, PA
    28
    244
    Re: Rebuilt Northstar, No Codes, Poor MPG
    replace both front O2 sensors and theres 90% chance this is your problem. It sounds like it.
    Also the dropping idle thing you are talking about, I remember that and it was the EGR valve. I had that all the time and always wondered. Then when it gets completely plugged it stalls teh engine every 30 minutes or so and takes 20 minutes to restart it. Clean/replace EGR valve and replace O2 sensors. I think this one is nailed down. Definately do the sensors though man, im telling you. You cant keep wasting premium like that..LOL. I knew something wasnt right before and sure enough it was them.
    I got mine here. http://www.partsamerica.com
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Ditto the O2 sensors. Coolant will damage them.
    Also a possibility the catalytic is clogged.
    Oct 2004
    Federal Way
    44
    351
    Hey, guys, excellent. I was pretty comfortable with the idea of these jobs - thanks for reinforcing my thoughts. I was going throug a LOT of coolant (burning) before the engine rebuild and I'm kinda torqued that my mehanic didn't replace the O2s, but it would have added to the cost and he probably didn't wanna call me ONE MORE TIME and say, "well, this is a lot more than I thought it was gonna be!!"
    I have my STS to do list now... and you're right Supreme is 3.50 here and way too expensive to be averageing 14.5 if I can get 17.5 out of it!
    BTW - never had to change a cat-con. Is this a special Northstar type made from precious metals??? I've just come to expect to pay more!
    This will pay for itself even sooner thanks to high gas prices... makes it far easier to swallow.
    Sep 2003
    Arizona
    3,531
    My brother had a Cougar that blew the head gaskets. After getting them done he had to replace both the O2's and the convertors. Coolant does not mix with either of them well. Many times they don't have to be changed but it does shorten their lives.
    I'd do the sensors first.
    As a matter of fact converters Are made of precious metals. Good thing they aren't made of diamonds.
    Oct 2004
    Federal Way
    44
    351
    I know the insides are - on the cats - just wondering if Cadillac decided to use specail golden cased cat cons!
    Just ordered two 02s from http://www.partsamerica.com for $55 each. Not bad. Turns out there are only two O2s on a 1994.
    Sep 2003
    Arizona
    3,531
    If you have to change the at I'd check on a direct replacement. They are usually much better quality than the universal weld in replacements.
    68
    81,922
    Check your FPR.
    Oct 2004
    Federal Way
    44
    351
    I have two direct replacements, they're Bosch I believe. If they are weld in, I'm sending them back.
    I now have a 3rd thing to check.
    So, I'm gonna replace the O2's, then the FPR, then the cat con. I think that is a good attack strategy.
    Anyone disagree?
    Thanks for all help/suggestions.
    GreenMachine's Avatar
    GreenMachine is offline Cadillac Owners Fanatic
    Automobile(s): 1998 Cadillac Deville
    Jun 2005
    Amherst (Buffalo), New York
    29
    484
    speaking of precous metals around here some are stealing catalytic converters off of all sorts of cars at dealerships, was story on the news.
    auroradude's Avatar
    Jun 2005
    WC, PA
    28
    244
    Oh you got the Bosch's? I thought you were going to get the Delco's, they are what I got. Try the Bosch's anyway if you got them, as long as they are OEM Replacement you shouldnt have a problem. I just didnt think ANYTHING non-delco electronic parts wouldnt work right on these cars.
    Oct 2004
    Federal Way
    44
    351
    Quote Originally Posted by auroradude
    I put in spark plug wires that weren't Delcos (before I knew this) and they worked perfect. They even had the exact same markings on them which made me think they supplied Delco.
    I didn't see Delco's on the list of where I bought from.
    Oct 2004
    Federal Way
    44
    351
    Replaced the front one, and it immediately cured the idle issue. Haven't driven enough to notice gas mileage yet.
    The back one looks like a PITA so I'm saving it for this weekend.
  16. #14
    silver duke is offline Cadillac Owners Member
    Automobile(s): 93 cadillac sts seville
    Oct 2005
    vancouver bc
    44
    hi there , i was just curious how much a rebuilt motor ran you in cost. was that a rebuilt or new motor from gm? who carries good rebuilt northstars?
  17. #15
    Oct 2004
    Federal Way
    44
    351
    US Engine in Kent, Washington and it was $3800 with timeserts and a 7 year 70,000 mile warranty. That was before labor....
  18. Remove Advertisements
