Results 1 to 9 of 9
Thread: Leaking anti-freeze poss waterpump area
    newetc's Avatar
    newetc is offline Cadillac Owners Fanatic
    Automobile(s): Eldo
    Jan 2004
    flori-duh
    134
    Hello folks, my 96 eldo has been good to me but lately little greamlings...
    It has 70k on the clock and it is the 4.6 northstar.
    It is leaking from the water pump area.. any suggestions.. i'll be taking her apart to look closer but wanted to know if this area has known problems.
    It leaks not only when running but also when it is parked.
    I have to fill the reservoir everyday now, i get the low coolant message.
    Thank you in advance for your help.
    TIA
    Bruce Nunnally's Avatar
    Bruce Nunnally is offline Cadillac Owners Member
    Automobile(s): 2008 Cadillac STS-V Spectre CAI, Corsa
    Feb 2003
    Texas
    56
    60
    Re: Leaking anti-freeze poss waterpump area
    This is not unusual if the waterpump needs to be replaced I think. You need a special socket tool to remove/replace the water pump, but your local Pep Boys or AutoZone may carry the tool and have it available to borrow. Replacing the pump is not a hard job most people report.
    69
    82,262
    Also the water pump front cover gaskets are known to leak and have been redesigned.
  5. #4
    Mountie's Avatar
    Mountie is offline Cadillac Owners Enthusiast
    Automobile(s): '93 STS (sold), now looking for a CTS Wagon soon!!
    Jul 2005
    Bradenton, Fl
    62
    502
    I replaced my Northstar..... I re-did everything. I recieved a lot of advice from some experienced Northstar dealer mechanics. A new waterpump costs around $130. It comes with a replacement 'o' ring. If I remember correctly, the 4" dia. removal socket is designed to fit against specific tabs on the pump. Removal is CLOCKWISE. Using a 1/2" breaker bar. CLEAN the pump pully opening edges.
    Installation: GREASE THE PUMP-TO-HOUSING OPENING, where the belt pully pokes through and where the tabs slip under the casting-tabs, using a heavy grease. ( This avoids corrosion at the seal).
    BE CAREFUL!!!!! Installing the waterpump, notice the little tabs that 'poke up'....these tabs are THE STOPS. Don't tighten anymore!! ( remember, you have an 'o' ring..... If you slightly over-tighten, you'll flatten these "tab-stops", and spin past the tabs on the housing. ( You have too much leverage with the breaker bar!!)
    Also, the thermostat housing is replaced of you have the plastic style . I put in an aluminum one. The housing has an 'o' ring gasget, and to the eye, the thermostat housing will not be completly against the waterpump housing, becaus the 'o' ring will do the sealing. ( Don't over tighten.)
    Then smoke a cigarrette.
  6. #5
    newetc's Avatar
    Automobile(s): Eldo
    Jan 2004
    flori-duh
    134
    Thank you everyone for the good information. I'm going to take her apart now and will report back the findings.... sounds like the gasket is gone..
    I did replace the belt and the thermostat last year when the belt snapped.
    I saw pumps for 66 bucks online.. is there an advantage with oem vs aftermarket..
    As far as the gaskets re-designed.. if i buy the new ones will i get the re-designed ones.. don't know what is different.
    Thank you.
  7. #6
    69
    82,262
    If you buy the gasket from the dealer, ($12) you'll get the redesigned one. I believe it has little nibs on it and is black. Not sure what the original one looked like.
    I think the OEM pump is made by Airtec.
  8. #7
    newetc's Avatar
    Automobile(s): Eldo
    Jan 2004
    flori-duh
    134
    Good news everyone.. just replaced my wp, o-ring and the other gasket.
    The wp did not look that bad but the o ring was gone... the other gasket was going real fast.. so now i got the new re-designed gasket, it is black and has the little studs.. nice fit... so i'm good to go for a while.. i already have the aluminum housing and i had replaced my thermostat last year so she is good.
    Thank you everyone for the help.. this job went real smooth..
    Next project, suspension and all filters..
  9. #8
    newetc's Avatar
    Automobile(s): Eldo
    Jan 2004
    flori-duh
    134
    btw.. my dealer gave me a good deal... 65 wp and 7 for the gasket..
    the old gasket was orange and flat.. the new looks much more robust.
  10. #9
    Captsolo is offline Cadillac Owners Member
    Automobile(s): 1993 eldorado
    Feb 2004
    bahamas
    34
    I have a 1993 Eldorado. People that read this are gonna criticize what I say now. I changed the coolent a few years ago and found a leak by my water pump. After purchasing a new pump and surfing the net, I found somewhere that from the factory Cadillac adds an "radiator sealer" to the coolent on their brand new cars. I added some to my leaking Caddy water pump and the leaking stopped.
    My feeling is I caused the problem when I had the GM dealer changed the coolent. They didn't know about Cadillac adding something (Aluminum something) to coolent from factory.
    Anyway, the car has been running for 4 years without that leaking problem.
    Don't believe me, but if you changed your coolent - that's what caused your leak.
    As you all know, once a "regular waterpump" starts to leak, you have to replace it. But a Cadillac waterpump on the 4.6 leter Northstar is anything but a "standard" water pump.
    Mines been in there for 13 year (from new) and still pumping without failure!
  • You may not post replies
