Post 2000 N*?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Northstar Engines and System Technical Discussion Discussion, Post 2000 N*? in Cadillac Engine Discussion; Hey All, I have heard that GM made alot of changes to the post 2000 N*'s. Anyone know the specifics ...
    bharner's Avatar
    bharner is offline Cadillac Owners Fanatic
    Dec 2003
    VA
    36
    238
    Post 2000 N*?
    Hey All,
    I have heard that GM made alot of changes to the post 2000 N*'s. Anyone know the specifics to that?
    Thanks
    68
    81,748
    Re: Post 2000 N*?
    They lowered the compression ratio just a tad to allow for regular gas. They replaced the flat tappet lifters with roller finger followers which extends the oil change intervals to a max of 12,500 under ideal conditions. They also did away with the plug wires by going to COP (Coil On Plug) ignition. There may be more, but that is all I can think of.
    Blown Z's Avatar
    Blown Z is offline Cadillac Owners Fanatic
    Mar 2006
    IL
    110
    Re: Post 2000 N*?
    Is it 2000 and up Northstars that had these changes? I've read in some other places that it was 2001 or 2002 and up.
  5. #4
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    49
    6,919
    Re: Post 2000 N*?
    No it is 2000 and up. I don't know the specifics if these but they also addressed the oil usage issue and coolant leaks that were notorious on the earlier N*.
  6. #5
    Eric is offline Cadillac Owners Fanatic
    Automobile(s): 2000 SLS
    Aug 2003
    SoCalif
    292
    Re: Post 2000 N*?
  7. #6
    Yaemish is offline Cadillac Owners Connoisseur
    Automobile(s): 02 Seville, 04 SRX
    Sep 2003
    NY
    1,223
    Re: Post 2000 N*?
    Does the head gasket problem still exist in the newer engines?
  8. #7
    68
    81,748
    Re: Post 2000 N*?
    Quote Originally Posted by Yaemish
    I think in 2000 or there abouts, they made some changes to the head bolts to reduce the possibility.
  9. #8
    Sep 2003
    Metro ATL
    4,854
    Re: Post 2000 N*?
    We could all benefit by a tiny terminology change here. Some very high percentage of head gasket failures can be traced back to an owner's failure to follow the recommended coolant maintenance schedule.
    Maybe the head gasket situation could be more accurately described as the "owner did not read the manual" problem?
  10. #9
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    Re: Post 2000 N*?
    I concur
    Quote Originally Posted by JimD
  11. #10
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: Post 2000 N*?
    Maybe the head gasket situation could be more accurately described as the "owner did not read the manual" problem?[/QUOTE]
    And what problem would that be?
  12. #11
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    Re: Post 2000 N*?
    Apparently there is a high rate of head gasket failure on the Northstars. In addition this failure is primarily due to lack of maintenance to the coolant system as specified in the owners manual.
    I don't really understand why older coolant would affect a head gasket but it does. And the coolant maintenance IS in the owners manual.
    Quote Originally Posted by El Dobro
  13. #12
    bharner's Avatar
    Dec 2003
    VA
    36
    238
    Re: Post 2000 N*?
    sorry ive been out of it. thanks for the info gents
  14. #13
    El Dobro's Avatar
    Sep 2003
    1,471
    Re: Post 2000 N*?
    Quote Originally Posted by codewize
    Finally convinced the dealer to change mine at 4 years and 55,000 miles. A lot of Northstars had to have the gaskets changed at even less, so how would that be due to lack of maintenence?
  15. #14
    blb
    blb is offline Cadillac Owners Fanatic
    Jul 2004
    173
    Re: Post 2000 N*?
    The thread pitch on the headbolts was changed to a more coarse thread in 2000, and this was supposed to address the premature headgasket failure prevalent in prior Northstars, but according to my contact at the dealer, they still see quite a few 2000 and newer models that have headgasket issues. In April, they had a black '02 STS in with 93,000 miles where the back bank headgasket was breached causing coolant to enter the exhaust.
  16. #15
    codewize's Avatar
    Apr 2005
    Upstate NY
    49
    6,919
    Re: Post 2000 N*?
    So is lack of coolant maintenance the cause or the catalyst? Or is this just a problem?
  17. Remove Advertisements
