It won't fire!!!!
Results 1 to 4 of 4
Northstar Engines and System Technical Discussion Discussion, It won't fire!!!! in Cadillac Engine Discussion; I just recently exchanged a 4.6 Northstar engine in my 1997 Deville. The engine that I replaced it with came ...
    lgriffin357 is offline Cadillac Owners Member
    Jan 2006
    Kosciusko,MS
    It won't fire!!!!
    I just recently exchanged a 4.6 Northstar engine in my 1997 Deville. The engine that I replaced it with came out of a 1996 Deville with the Northstar engine (eight digit "Y"). Eveything connected fine, except now it won't fire. The engine turns over but it will not start. Any suggesstions? I checked and re-checked the ground wires, but still no success.
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: It won't fire!!!!
    1st get some starting fluid spray it into the throttle body to see if its a fuel problem. if its not fuel then check for spark. also pull the codes!!!
    Jan 2006
    Kosciusko,MS
    Thanks for the quick response, I will post response. Are there anymore suggestions other than that?
    Oct 2005
    15,987
    before i make any other major suggestions i wanna know if its a fuel or a spark problem causing it not to fire it has to be one of the two from their we can proceed but pulling the codes will also majorly help
  7. Remove Advertisements
