Engine on or off during On Board Diagnostics?
Results 1 to 11 of 11
Northstar Engines and System Technical Discussion Discussion, Engine on or off during On Board Diagnostics? in Cadillac Engine Discussion; I am diagnosing my P071 code, and am wondering if, the engine should be running or not when t-shooting?...
    ddias1 is offline Cadillac Owners Member
    May 2006
    Fresno, CA
    39
    8
    QuestionEngine on or off during On Board Diagnostics?
    JimHare's Avatar
    JimHare is offline Cadillac Owners Connoisseur
    Automobile(s): 01 Eldo ETC, 02 Deville SOLD!
    May 2004
    Salem, NJ
    64
    1,815
    Re: Engine on or off during On Board Diagnostics?
    What kind of troubleshooting do you mean? The engine is OFF (but Key in Start position) to retrieve the DIC codes, but after that? Not sure what you meant by 'troubleshooting'....
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    to retrieve codes engine can be running or off.
    Depending on the tests perfoming, you will want the engine either running, or off...
    May 2006
    Fresno, CA
    39
    8
    I'm using the Alldata fualt tree for P071. It says to check the value of PD02 in the PCM data menu of the OBD. If the value is 20-85kPa then I have a bad MAP sensor. The value changes if the motor is running or not......
    peteski is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Eldo Biarritz
    Dec 2003
    Northeast USA
    808
    So, what is your question?
    If you checked PD02 with the engine off, if should steadily indicate the barometric pressure where the car is at. I'm close to sea level, so I would expect something around 100-104kPa.
    When the engine is running, the values you show sound right. When the car is idling, it should be close to the low range (20s). When you open up the throttle, the value will go up. So, if it showed 20-80 at various throttle settings, then the MAP sensor would be good.
    Sounds like the Alldata fault tree is not all that well written...
    Peteski
    May 2006
    Fresno, CA
    39
    8
    Thanks for the reply peteski! Yeah, the AllData test is pretty vague. Right now at idle its at 33-34kPa. I'm below sea level, not really sure how much. Its about 95 degrees here. With the engine off, I'm reading about 101kpa. I cleared my codes and P071 keeps coming back...any other suggestions for testing the MAP sensor? What else could be causing this?
    May 2006
    Fresno, CA
    39
    8
    I know this sounds out of left field, but could my battery be a cause?
    Dec 2003
    Northeast USA
    808
    You're below sea level!? Hmmm... Not many dry places are...
    I also think that your readings look perfectly normal. If I remember, I'll check mine (on my 93 Eldo) next time I go driving.
    Peteski
    JimHare's Avatar
    May 2004
    Salem, NJ
    64
    1,815
    Quote Originally Posted by peteski
    The ones in Death Valley are.. Fresno is nowhere near D/V but you can never tell with California..things shift around there a lot..
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    32
    3,703
    Quote Originally Posted by ddias1
    They don't call it NoData for nothin'
    Dec 2003
    Northeast USA
    808
    Last night I've checked the PD02 in my 93 N* Eldo.
    With engine off it read 102. With engine idling around 750RPM, it read 37. Of course when I stepped on the throttle, the reading changed (went up when acccelerating and even under 37 when decelerating).
    Peteski
  14. Remove Advertisements
