oil filter adapter
Results 1 to 3 of 3
Northstar Engines and System Technical Discussion Discussion, oil filter adapter in Cadillac Engine Discussion; I see that there was a change in part#s in mid 97 for the oil filter/cooler lines adapter that mounts ...
    parts68 is offline Cadillac Owners Fanatic
    Automobile(s): 02 Escalade,96 Aurora,with Shelby engine
    Jan 2006
    345
    oil filter adapter
    I see that there was a change in part#s in mid 97 for the oil filter/cooler lines adapter that mounts on side of block.
    I broke one on the 95 and need a replacement.
    Just wondering if the change was only due to increasing the pipe thread hole for oil pressure sensor. (it changed from 1/4 to 3/8).
    Anyone got a good one?
    blunted is offline Cadillac Owners Enthusiast
    May 2004
    NYC
    585
    Re: oil filter adapter
    I went thru serious drama with that part on my 94.. but yes you're correct. The 2 differences that came up were with/out oil cooler holes and the plus sized thread for the pressure sensor.
    Jan 2006
    345
    Yea I found one thats the supeceded part.
    Has the cooler line tapped but the oil pressure sensor hole is tapped to 3/8.
    I just added a 3/8-1/4 threaded bushing and all is well.
    I also found one in a JY that has only 1 tapped hole for oil cooler lines,with a threaded plug in it,and the other boss isnt drilled or tapped.
