95 Eldorado occasional starting problem.
Results 1 to 8 of 8
Northstar Engines and System Technical Discussion Discussion, 95 Eldorado occasional starting problem. in Cadillac Engine Discussion; Soon as I get ready to sell my Eldorado it stat=rt giving me problems. First the coil, then the thermostat ...
    Infamous Lac is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado ETC
    Mar 2003
    POMONA, CA
    113
    Soon as I get ready to sell my Eldorado it stat=rt giving me problems. First the coil, then the thermostat now this. Occasionaly my Edlo takes a few turns to start up, I get no crank or a slight crank sopmetimes. It always will crank and turn on atleast by the third or fourth turn. The battery is good at 12.0 volts, tends to like to do it after car is pointed toward the sun and its hot outside. Does this sound like and ignition switch, I want to make sure before spending any money on a new part.
    68
    81,744
    Re: 95 Eldorado occasional starting problem.
    Quote Originally Posted by Infamous Lac
    No, it sounds like it is possessed.
    dp102288's Avatar
    dp102288 is offline Cadillac Owners Connoisseur
    Apr 2006
    North Brunswick, NJ
    28
    4,236
    Its telling you not to sell it.
    Try to pull the codes for it.
  5. #4
    Mar 2003
    POMONA, CA
    113
    Its not displaying any new codes, only the same egr valve code. It did it again this morning a short fraction on a sec crank, then nothing, nothing and then fries right up. With how gas prices are now Im am almost willing to give this thing away. Im getting like 14-16 mpg.
  6. #5
    Feb 2004
    FL
    2,250
    I'll take it.
  7. #6
    68
    81,744
    Clean the EGR valve.
  8. #7
    TripleblackETC is offline Cadillac Owners Fanatic
    Automobile(s): '95 Eldorado black on black
    May 2006
    Western Massachusetts
    32
    133
    I have the exact same problem with my '95 ETC. I told my mechanic about it and he thinks it's the fuel pump. It is weird; when it's real cold out it fires right up. If it's been off all night and you try it in the morning it fires right up. But once you drive it and try to start it again it take 3 or 4 turns. No codes come up for me either.
  9. #8
    68
    81,744
    Quote Originally Posted by TripleblackETC
    Your problem sounds like a bad FPR. Go to the Tech Tips section for a "How To" check it. Very simple.
  10. Remove Advertisements
