A/C recharge
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, A/C recharge in Cadillac Engine Discussion; Hello I read the thread on the A/C charge and appreciate you RANGER! I am doing maintenance on the water ...
    mikeri is offline Cadillac Owners Member
    May 2006
    Beautiful Alabama
    57
    3
    A/C recharge
    Hello
    I read the thread on the A/C charge and appreciate you RANGER! I am doing maintenance on the water pump, and while checking it out after install, I realized that the coolant level was low and it disabled the compressor. After flushing the system and resetting the code, I put in about 18 OZ of 134a and still the compressor won't come on. What am I doing wrong? It worked perfectly before. Should I come accross the system to the fuse link to "hot wire" the compressor temporarily so it will accept the 134a?
    Thanks
    69
    82,190
    Re: A/C recharge
    When you say coolant, I assume you mean refrigerant.
    If the compressor was disabled, you have to clear the codes BEFORE adding refrigerant. You must have everything hooked up and ready to go, THEN turn the A/C on to recarhge or it will detect low freon and disable the compressor again.
    May 2006
    Beautiful Alabama
    57
    3
    Re: A/C recharge
    Thanks Ranger!
    jrw_57 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2007
    Re: A/C recharge
    How do you clear the codes??
    jrwr_57
    69
    82,190
    Re: A/C recharge
    The "sticky" in the Tech Tips section will explain it.
  8. Remove Advertisements
