Results 1 to 12 of 12
Thread: Putting Northstar on an Engine Stand
    Mike7075 is offline Cadillac Owners Member
    Automobile(s): 1996 Deville
    Apr 2006
    14
    Since the Northstar is an all aluminum engine, will four bolts where the transmission bolts up support the engine on an engine stand with all of the accessories attached? Also, does anyone happen to know what thread size this is (SAE or metric)? Did GM put inserts/helicoils on all threaded holes on this engine, or only the threads for the heads to bolt up? Iíve seen pictures with Northstars on engine stands, but just want to avoid any stress cracks at the transmission mounting area. Thanks.
    69
    82,262
    Re: Putting Northstar on an Engine Stand
    There are no inserts on any of the threads holes. They are all threaded into aluminum. If you pull the head bolts, be sure to Timesert http://www.timesert.com/ all 20 bolt holes. DO NOT use helicoils for the head bolts. They won't hold.
    Feb 2004
    FL
    2,250
    I supported an engine w/o accessories on a stand... I was a little nervous about the threads getting screwed up or something too, but I guess it's probably fine. The more weight you can take off, the better. The bolts are metric, I don't remember offhand what they are, but I think they were like 100-120mm long, maybe m12(?). That's what I believe worked with my stand. They were tough to find. I had to notch the stand's arms to clear the coolant crossover...
  5. #4
    Mar 2004
    Nashville, TN
    367
    I've had mine on the stand fully loaded for a month and no problems. I did have to find the bolts at a fastener store...If I remember correctly, the bolts are the same thread and pitch as the cradle to body bolts.
  6. #5
    parts68 is offline Cadillac Owners Fanatic
    Automobile(s): 02 Escalade,96 Aurora,with Shelby engine
    Jan 2006
    345
    Maybe find a grade 8 bolt that next size smaller to slide thru the hole and put a steel nut and large flat washers.
    No strain on the threads in block.
  7. #6
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    If you snug the bolts they (and the block) are plenty strong. Even with accessories you will have no problems as long as you don't knock it over.
  8. #7
    Apr 2006
    14
    I was surprised to find that there are only three bolts on the bellhousing instead of the usual four. I am mounting the Northstar on the engine stand tonight...12mm 1.75pitch I believe is the thread size. I had to have two of the engine stand arms ground down to clear the coolant crossover, too.
  9. #8
    Feb 2004
    FL
    2,250
    There are 4.
  10. #9
    Jan 2006
    345
    3 ea 12x1.75x65
    1 ea 12x1.75x50
  11. #10
    cart69's Avatar
    cart69 is offline Cadillac Owners Fanatic
    Automobile(s): 96STS engine only!! only thing left from my 96 after divorce
    Dec 2004
    Illinois
    37
    150
    there are 4 bolts, and i just took the crossover off mine to put it on the stand its been sitting on the stand for 2 months now complete engine no problems, wanna buy it!!!
  12. #11
    Apr 2006
    14
    Thanks for the offer Cart69, but I picked up an engine last weekend. Just for giggles, how many miles on it and what would you sell it for?
    I only see 3 threaded holes around where the bellhousing would bolt up on my Northstar. There are also 2 larger holes for large dowels to line up the trans. Is this fourth threaded hole behind the water crossover or something? I have it on the stand with the crossover still bolted on. I haven't pulled the engine out of the Deville yet, so I don't know how the trans bolts up, by I can only find three 12mm threaded holes on the back of my replacement Northstar? Am I crazy, blind, or other?
  13. #12
    cart69's Avatar
    Dec 2004
    Illinois
    37
    150
    i would sell mine for 300 its got 102k miles and runs good besides the coolant leak!!
    there is 4 bolt holes i think one is inside one of the larger dowel holes too
  • You may not post replies
