northstar swap into another car, a few questions
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, northstar swap into another car, a few questions in Cadillac Engine Discussion; does anyone know: the physical dimensions of the engine(without tranny)? how much boost the northstar can take reliably? the redline ...
    User Name is offline Cadillac Owners Member
    Apr 2006
    1
    does anyone know:
    the redline rpm?
    are they unreliable? I have heard some bad things about head gaskets....
    i'm contemplating doing something similar to the many fiero northstar swaps. I'm torn between using the L67 3800 SC series II or the transverse Northstar. Both share the same bellhousing so it comes down to size, reliability, and potential.
    davesdeville's Avatar
    davesdeville is offline Banned
    Automobile(s): 1995 ETC, 75 Deville, Cad500 powered 73 Apollo, 94 Mark VIII
    Aug 2003
    Albuquerque, NM
    29
    7,971
    Re: northstar swap into another car, a few questions
    28"W, 26"H, 31"L 400lbs bare, 415 ready to run, 470 with full accessories.
    Or so I've heard.
    A stock motor should take 6-8psi so long as you run good enough gas. Forged internals and the sky's the limit really.
    Headgaskets are a PITA if the motor's in the car. If you get one with a blown HG you can probably get it cheap. While you have it out, timesert it, keep up with coolant changes and never worry about it again.
