Name That Part
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, Name That Part in Cadillac Engine Discussion; I have yet to locate a FSM and since I am still under warranty I am not in a big ...
    69
    82,171
    Name That Part
    I have yet to locate a FSM and since I am still under warranty I am not in a big hurry, but I see two items under the hood that I am unsure of. I think these are the same for all post 2000 Northstars.
    The first is a square module mounted dead center on the firewall. Since the 2000+ has COP (Coil On Plug) vs the coils mounted on the ICM, I suspect this is the ICM.
    The second one, I am clueless. Looking at the firewall from the front of the car, Just to the left of the previously mentioned module there is a valve of some sort mounted on the rear cam cover. It has a vacuum hose on the top of it, what appears to be a rubber coolant hose (about 3/4 - 1" in diameter) off the side (may not be coolant) and a corrigated flexable aluminum tube (like the EGR tube) off the bottom. What is it?
    Feb 2004
    FL
    2,250
    Re: Name That Part
    y2k northstar's don't have an ICM as far as I'm aware. The coilpacks plug straight into the PCM.
    The second "valve" sounds like something that has to do with the PCV, but hard to tell without pics.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Re: Name That Part
    I just changed my spark plugs on the car, and am aware of the part you speak of. I am not sure what it is, but looks like it has something to do with the EGR. It has the flex pipe that EGR's normally have, and the vacuum ports also. I will search a bit, and see what i can come up with.
    Don
    69
    82,171
    Re: Name That Part
    Quote Originally Posted by eldorado1
    Something still has to tell the coils when to fire. That would be the ICM, right?
    Feb 2004
    FL
    2,250
    Re: Name That Part
    Quote Originally Posted by Ranger
    Nope, the PCM tells the coils when to fire. Before, the crank and cam sensors went to the ICM, but y2k brought about the elimination of the ICM... So the crank and cam sensors go straight to the PCM, along with the control of the coils.
    69
    82,171
    Re: Name That Part
    OK, in that case, I have no clue on either part. No one knows? No one with a manual?
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Re: Name That Part
    The part over the cam cover is the secondary air vent solenoid. I have no idea what it is for though.
    Don
    Feb 2004
    FL
    2,250
    Re: Name That Part
    sounds like a handy thing to have in case the primary air vent solenoid cops out on you...
    69
    82,171
    Re: Name That Part
    "Secondary air vent solenoid"? The plot thickens.
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Re: Name That Part
    Maybe secondary AIR vent solenoid makes more sense?
    Don
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    Re: Name That Part
    AIR as in Air Injection Reaction?
    Smog system?
    WOTMODE is offline Cadillac Owners Fanatic
    Jan 2004
    Minneapolis area
    117
    Re: Name That Part
    Secondary AIR injection is just like old AIR pumps on '70s and '80s cars except it has an electric pump and electronic controlled solenoids and valves. It doesn't hurt power, only helps pollution. To mess with will turn on check engine light.
    69
    82,171
    Re: Name That Part
    OK, upon further inspection, the module mounted on the firewall is for the cruise control. I noticed a cable coming out og the side that I didn't see the first time, and it runs to the throttle linkage.
    The secondary air vent solenoid, as Dadillac called it has a twin. She is mounted just behind the radiator under the radiator hose, between the water pump pully and the air box. What I thought was a coolant hose appears to be an air hose and the corrigated flex pipe under is runs to the appropriate exhaust manifolds. As mentioned, it appears to be vacuum operated and I see no electrical connections so I don't know how they could call it a solenoid. At any rate, it does appear to be supplying fresh air to the exhaust manifold as the old A.I.R. pumps used to. What I can't figure out is where the supply is coming from and how it overcomes exhaust manifold pressure to keep the flow from backing up as I could see no pump of any sort. I gotta get a FSM.
  16. #14
    AlBundy's Avatar
    AlBundy is offline Cadillac Owners Master
    Automobile(s): 1996 Eldorado Sport Coupe, 2009 Black Navigator
    Jul 2005
    Chicago
    41
    5,023
    Re: Name That Part
    When ever I go on ebay I've been on the lookout for one(fsm) for ya. If one comes along I will let you know.
  17. #15
    69
    82,171
    Re: Name That Part
    Thanks Al. Much appreciated. I check from time to time myself, but those '02's are scarce as deer on opening day.
  18. Remove Advertisements
