voltage drops when car in drive
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Northstar Engines and System Technical Discussion Discussion, voltage drops when car in drive in Cadillac Engine Discussion; i have a 1995 cadillac eldorado with the northstar motor. When the car is in park i have about 12 ...
    louie k is offline Cadillac Owners Member
    Apr 2006
    3
    i have a 1995 cadillac eldorado with the northstar motor. When the car is in park i have about 12 volts, when i put the car in drive the volts drop rapidly down to about 8. When i put the car back in park the volts go right back up to 12. The belts are working. does anyone know what might cause this?
    thnx in advance
    louie
    Feb 2004
    FL
    2,250
    Re: voltage drops when car in drive
    How are you measuring voltage? I wouldn't trust any gauges... Use a volt meter at the battery terminals and confirm those readings. 12 volts is very low, you should be seeing around 14 at idle.
    1993 eldorado green1's Avatar
    1993 eldorado green1 is offline Cadillac Owners Fanatic
    Apr 2004
    michigan
    40
    176
    yep, what eldorado said. 14 at idle and it should stay about the same in drive although it may drop a little if your running accessories and such.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    If the lights are flaring from orange to bright with engine speed, the battery is shot.
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    Or your voltage regulator is bad.
    Same thing if you hit the brake and the headlights momentarily dim a bit and come back (less than a second).
    Apr 2006
    3
    it says how many volts for the battery in the dash. when i start the car and let it idle it says 12.5 or around there, then when i put the car in drive it drops down to 8 and says battery volts low, i have air conditioning off, radio off, lights off in car. i checked the battery with a tester when the car was off and it said 2/3 full. i havent checked it when the car was in drive though.
    When i hit the brake my headlights do dim of less than a sec and then come back
    Apr 2004
    michigan
    40
    176
    Quote Originally Posted by louie k
    sound to me like its time for a new alternator man.. there not too bad to change
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    There's a part in the alternator called a rectifier. If one of the diodes in the rectifier goes it acts like that.
    blunted is offline Cadillac Owners Enthusiast
    May 2004
    NYC
    585
    Not to thread jack.. but you guys are getting me paranoid. Mines never at 14.. i get 13.5 max. I'm running at 7" Head Unit and 3 12"subs 1000W Amp, however I dont constantly have them blasting. Everything seem ok there? I got a Yellow Top as well.
    Feb 2004
    FL
    2,250
    Again, check at the battery with a meter to confirm. It could be a simple wiring problem, or nothing to worry about.
    As an example, my ECM was showing 13.5 volts running, but I measured at the battery to be 14.5 volts. Now I know it's not the alternator, so I stopped worrying about it. A 1 volt drop is more than I'd like to see, but short of ripping out wires and buying all new connectors and smearing everything with new dielectric grease, there's nothing I can do.
    Polski Polak's Avatar
    Polski Polak is offline Cadillac Owners Member
    Automobile(s): 1996 Seville SLS
    Sep 2005
    Connecticut
    28
    82
    how do u know whether its the alternator or the battery, my headlights dim when I roll up my window should i look into a battery or alternator??? thanks in advance!!!
    Feb 2004
    FL
    2,250
    You can have your battery tested at Autozone or similar. The alternator can be tested in the car at the same.
    acklac7 is offline Cadillac Owners Fanatic
    Automobile(s): '95 White Diamond Eldorado Biarritz
    Jul 2003
    184
    Quote Originally Posted by Zorb750
    Where is the voltage regulator located at ? ....For the past few years my headlights have dimmed when I apply the brakes....The engine will also make a slight noise at the same time....A buddy of mine said this was indicitave of the engine "looping" or something like that...BTW my volts rarely read over 13.5...when I have accessories running the voltage is in the mid-high 12's...Which is way to low I believe...I'd love to fix the problem...If it's something cheap and simple
  16. #14
    caddyfanatic2 is offline Cadillac Owners Member
    Dec 2005
    44
    My headlights on my mazda 626 dimmed when i hit the brakes too. I figured it was something to do with the circuit that did the bulb check. But I've been noticing it on my Cadillac too. What could that be? Dont all cars do that?
  17. #15
    thu's Avatar
    thu
    thu is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 STS w/BoseNav, 1993 Deville, 1985 Deville
    Jul 2003
    Wyoming
    1,089
    You can also just take your car down to Sears Automotive. They'll test the entire electrical system for you. Some stores to it for free; others charge a tiny fee. Many will waive the fee if you buy a batt, alternator, etc.
  18. Remove Advertisements
