DIY Replace Coolant for 94 STS
Results 1 to 5 of 5
Northstar Engines and System Technical Discussion Discussion, DIY Replace Coolant for 94 STS in Cadillac Engine Discussion; I got "Check Coolant Level" message in a cold morning so I bought some $8 coolant from WM and tried ...
    alch is offline Cadillac Owners Member
    Feb 2006
    47
    I got "Check Coolant Level" message in a cold morning so I bought some $8 coolant from WM and tried to replace it by myself. The first problem is I can not find the coolant cap coz there is no "Coolant" text on any cap, so I checked user manual and found it is supposed to be the silver cap with "15lb closed system" on it - correct me if I am getting the wrong cap.
    Now if I am right, my problem is - I can not open it by my hand, it is so tight that I doubt I have to use some tools to open it, anyone can confirm this? Or it is only my problem? Is coolant check included in regular Jeff Lube oil change?
    Thanks!
    jr
    68
    81,760
    Re: DIY Replace Coolant for 94 STS
    Yeah, I think you have the right cap. Place the heel of your hand on it and press down while rotating it. After you fill it (1 1/2" - 2" from the top) replace the cap the same way. There are two stops on the cap so make sure you lock it into the second one or you'll overheat.
    Yes, I would think jiffy Lube should at least check the coolant level.
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    A strap wrench makes it easier. That way one hand pushes down and one rotates the wrench.
    And I would hope Jiffy Lube would not check the coolant level. It takes 20 minutes at least to cool down to the point you can open it. They would have to be beyond stupid to do that. Besides, when hot the level will be higher. Much higher.
    I would NEVER take a car to Jiffy Lube. Them with their impact gun to put on the oil plug.
  5. #4
    68
    81,760
    Quote Originally Posted by Zorb750
    Good point, but most cars have a translucent tank, so it is easy to check without opening the system.
  6. #5
    STS 310's Avatar
    STS 310 is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 STS
    Dec 2003
    LOS ANGELES CA
    1,489
    Boy does Jiffy get a bad rap...
    SOME of those guys know whats up, and remember that I emphasized "some".
  7. Remove Advertisements
