another problem solved! N* stutter gone
Results 1 to 2 of 2
Northstar Engines and System Technical Discussion Discussion, another problem solved! N* stutter gone in Cadillac Engine Discussion; hey guys i figured i would share my results with everyone while i'm so ecstatic. first off, i had a ...
    samm is offline Cadillac Owners Fanatic
    Automobile(s): 2002 STS
    Sep 2004
    SE Minn.
    30
    370
    first off, i had a stutter/hesitation in my 99 SLS, and it continued to get worse, for about 4 months. i came here on the forums and i noticed that this is a common association to bad spark plugs/wires. so, eventually got enough money to get some new plugs and wires (i got AC plugs and Belden(sp?) Max wires). The good news is my once rough N* now drives as smooth as a baby's behind again.
    So, if any of you all find yourself with a stutter in your N*, which may feel like a cylinder not firing under a bit of a load, as well as bogging down then "exploding" in WOT, then bad plugs and/or wires could be the culprit.
    Thank you everyone on these forums, i appreciate the help you guys give out every time.
    SAM
    cart69's Avatar
    cart69 is offline Cadillac Owners Fanatic
    Automobile(s): 96STS engine only!! only thing left from my 96 after divorce
    Dec 2004
    Illinois
    36
    150
    Re: another problem solved! N* stutter gone
    good deal, my 94 had an identical problem, plugs and wires fixed it as well, an amazing difference they can make
